Joist Hangers For Old Lumber. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 12:19 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Joist hangers for old lumber.
I have joists that are 1 3/4" actual thickness.
Simpson Strong-tie has hangers that are made for LVL (HU7) so they would fit perfectly. Since I'm hanging 16 joists, the problem is the price for these hangers.
There's a less expensive hanger made for rough lumber 2" actual (LU28R-18 or LU26R) that's a few bucks cheaper. Any issues if I use these with a 1/4" shim to make up the difference?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-02-2010, 01:20 AM   #2
Registered User
Rewards Points: 4,894
It depends on the local Inspector. I've side shimmed 5-6 times on LU, never on LUS (shear) and was OK. Make sure the hanger is for the correct species in Rough Wood: http://www.strongtie.com/products/co...index-face.asp Try 1/4" plywood.
Be safe, Gary
Old 01-02-2010, 12:57 PM   #3
I have gas!
Thanks GBR,
I know it wouldn't work on a double shear hanger as the nails would be incorrectly placed.
I was thinking gluing on a shim and running with it. The cost difference is about $100 for 16 hangers and I don't have a problem spending the extra but I think if the shim idea works just as well, it would be a waste of money.
question about joist hangers with drywall redss Drywall & Plaster 4 10-15-2009 03:01 PM
Installation of joist hangers angusbrown Building & Construction 2 06-26-2009 10:52 AM
How to fit joist hangers on "swollen" joists drh Building & Construction 2 02-22-2008 12:20 AM
Joist Hangers handy man88 Building & Construction 1 10-28-2007 11:12 PM
Simpson Joist Hangers NateHanson Building & Construction 5 10-02-2007 04:11 PM
