Joist Hangers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-28-2007, 05:19 PM   #1
Rewards Points: 1,088
Joist Hangers
I'm looking for joist hangers that are 12" in length. I need these because my house has TGI's (engineered Ibeams) and in one area, the TGI's are secured onto a header board, not on top of a solid steel beam or concrete wall.
I can use laminate board to fill the beam's cavity, but there are no joist hangers long enough to be found at Home Depot because their joist hangers are for boards. Is there a site online to buy them?
2 x 12 joist hangers (two)
double 2 x 12 joist hangers (one)
handy man88 is offline   Reply With Quote
Old 10-28-2007, 10:12 PM   #2
robertcdf's Avatar
Simpson makes them. White cap should have them or your local REAL lumber yard. Worse comes to worse you could special order them from HD. what I imagine you are looking for is a top flange hanger (this may or may not work depending upon size of your ledger) It should be speced on your stamped plans from your building department. If you need to find the exact number goto http://strongtie.com/ and poke around till you find it. (11 7/8" is your joists size)
robertcdf is offline   Reply With Quote
Simpson Joist Hangers NateHanson Building & Construction 5 10-02-2007 03:11 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 09:56 PM
Can I use my nailgun for joist hangers MIKEGOUGH1 Building & Construction 3 12-20-2006 01:09 PM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 02:02 PM
