Joist Doesn't Match Dimension Of Joist Hanger! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 12:50 AM   #1
Joist doesn't match dimension of joist hanger!
I am building a shed in our back yard, and I got some Simpson PF26 joist hangers at Home Depot, but the 2x6 studs that I got are almost 1/4" too tall for the hangers! Must I go and notch the ends of each joist? Am I missing something?
Stan Shmenge is offline   Reply With Quote
Old 03-15-2011, 07:23 AM   #2
The height of a 2x6 is roughly 5 1/2", but can vary depending on the mill, moisture content, etc. The best way to lay out joists is the use a piece of scrap 2x6 and mark the bottoms on your beam or ledger for hanger placement.
Old 03-15-2011, 07:39 AM   #3
Rewards Points: 5,336
Yes, your missing something. Just follow Bill's advice.
Ron
Old 03-15-2011, 07:41 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Stan, Welcome to the Forum
The PF26 hangers are 5-3/8'h
standard 2x6's are 5-1/2h
You don't have to notch anything if you have standard size lumber
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-15-2011, 04:21 PM   #5
Originally Posted by palibob View Post
stan, welcome to the forum
the pf26 hangers are 5-3/8'h
you don't have to notch anything if you have standard size lumber
5 3/8" <> 5 1/2"
Old 03-15-2011, 05:37 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
5 3/8" <> 5 1/2"
Obviously the joists will stand slightly proud of the connection, but then so will the hanger-hanger.
XXX
Old 03-15-2011, 05:52 PM   #7
Tool Geek
PaliBob's Avatar
Just use a conventional face mount hanger
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-15-2011, 05:54 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just use a conventional hanger.
Or a bigger hammer.
XXX
Old 03-15-2011, 06:54 PM   #9
I've already notched the 2x6's. Looking good.
Old 03-15-2011, 08:35 PM   #10
Registered User
Rewards Points: 5,224
The 1/8" is for the standard shrinkage of a 2x6 from 19% MC at the mill, to installed thickness at 11%MC after building is heated. Your engineered lumber (LVL, ParaLams, Glulams, I-joist, etc.) doesn't shrink at all, takes different hangers so the tops are installed flush. Page 51; http://books.google.com/books?id=iwS...rafter&f=false
Gary
Gary in WA is online now   Reply With Quote
Used wrong nails for joist hanger odlaw Remodeling 14 05-28-2011 11:26 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Joist Hanger Question? mopowers Carpentry 11 08-22-2010 02:56 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
