Old 12-22-2011, 11:04 PM   #1
Joint between chimney and wall
I have searched the internet but couldn't find a definite answer.
What is the correct way to seal the joint where a wall meets a brick chimney? The wall will be 1/2" sheathing -> house wrap -> vinyl siding.
REXAMUS is offline   Reply With Quote
Old 12-22-2011, 11:14 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Can you post a picture.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 12-22-2011, 11:23 PM   #3
Disabled wood vet
titanoman's Avatar
The sure way is to notch a groove into the brick that metal flashing inserts into and goes under the vinyl.
The lesser reliable way is to just run a good bead of 100% silicone under the vinyl corner trim and press it onto the brick; or a combination of the two.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-22-2011, 11:25 PM   #4
None available right now but I found this and it's pretty much the same minus the vinyl siding part.
http://www.flickr.com/photos/2801617...57605835178607
(example^) not actually mine.
I currently do not have the vinyl siding up and it's just the sheathing and housewrap.
Old 12-22-2011, 11:53 PM   #5
gregzoll's Avatar
J-Channel would be the more professional way of doing it.
Old 12-23-2011, 12:02 AM   #6
that chimney is not functioning right looks like its condensating inside...is there a flue linner in there...if not needs one...
Old 12-23-2011, 12:04 AM   #7
gregzoll's Avatar
Ben, that picture as the OP stated is for an example of the project at hand. Not the actually structure that the OP owns, or in the process of working on, as they stated.
The Following User Says Thank You to gregzoll For This Useful Post:
ben's plumbing (12-23-2011)
Old 12-23-2011, 12:04 AM   #8
Disabled wood vet
titanoman's Avatar
That's not their chimney.
The Following User Says Thank You to titanoman For This Useful Post:
Old 12-23-2011, 12:06 AM   #9
yea by bad.....up to long thanks..
Old 12-23-2011, 12:07 AM   #10
yep by bad been up to long thanks..
Old 12-23-2011, 12:12 AM   #11
ohttp://www.certainteed.com/products/trim/trimboards/317641f
I like to use this instead of J molding.
Much more ridged so it's less likly to flex and crack the caulking. It's
also wider to cover the gap between the wall and the chimney.
Old 12-23-2011, 04:38 AM   #12
So j-channel is sufficient enough? That's what I planned on using I just thought maybe I was missing something. Thanks!
Old 12-23-2011, 05:19 AM   #13
Disabled wood vet
titanoman's Avatar
So am I wrong (post #3)?
(I didn't mean "corner" trim in the alternative method. I meant whatever you call the finishing piece of vinyl you would use to cap the end of the siding whenever it butts into something. I guess it's in the shape of a "j". But since water can get behind "j" channel, isn't my first solution correct?)
Old 12-23-2011, 08:50 AM   #14
gregzoll's Avatar
As long as the flat is long enough to go past the siding. Then again, if water does get in back, it should just roll down the house wrap and should not get behind, if everything is done correctly.
Old 12-23-2011, 10:42 AM   #15
"Nail-Bender"
End the vinyl siding into "J", channel - "channel", against the bricks.
You can caulk between the bricks and the "J" channel -
"Quad", "Solar Seal", "Vulkem".
Don't caulk inside the "J" channel - ("channel to siding").
Make sure all surfaces are dry, clean, and frost-free - before you do any
caulking!
rossfingal
rossfingal is offline   Reply With Quote
Moisture on interior chimney wall, need advice stock2mal Roofing 9 07-09-2011 07:57 AM
retaining wall around chimney stack Master Brian Building & Construction 0 08-25-2010 04:27 PM
Chimney vented wall furnace JohnH1 HVAC 3 12-22-2009 08:54 PM
Where a wall meets a chimney joelbuckley Carpentry 12 11-13-2008 04:19 PM
Moisture-proofing chimney box wall penetration faithmyeyes Roofing 3 01-06-2007 12:23 AM
