Joining Gutter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 08:28 AM   #1
Arrow
joining gutter
Hello,
I have to join two 10ft runs of aluminium k-profile gutter onto either side of a drop section:
The end product will look like in the lower-right corner of this picture:
Now, I have several options of doing the two joins:
  1. using two crimp-on "seamers" to cover the seams between the two 10ft runs and the drop
  2. using two slip-on connectors to connect the two 10ft runs to the drop
  3. getting (or fabricating) a drop section which already has, on either side, the kind of interlocking slip-on connectors do (essentially a double-fold before extrusion to create the slip-on lip)
  4. reduce the ends of the two 10ft runs and slip them into the drop section then mechanically fastened (screws on the front and back)
I cannot go with seamless since one of the two 10ft segments "belongs" to me, while the other one is the neighbour's (who will have to replace her fascia in the coming years and tear the entire thing down again.)
The 10ft runs are pitched 1/2".
Because the joinery is extremely visible (man's height level and right at the entrance) I would prefer methods #3/#4 over #1/#2 because they have the minimal number of seams. However, I have yet to see an off-the-shelf part fitting the bill for #3 -- and #4 is barely mentioned anywhere.
Is there anything obviously wrong with #4?
Thanks!
V.
vladr is offline   Reply With Quote
Rain gets underneath gutter Heimwerker Roofing/Siding 8 12-28-2011 12:59 AM
Gutter leaks after roof replacement Jim F Roofing/Siding 6 04-16-2010 08:42 PM
Rain gutter slopes the wrong way ovahimba Roofing/Siding 2 12-20-2009 03:56 PM
Squirrels chewing the gutter guards... gshock Roofing/Siding 1 04-12-2009 12:47 PM
"Frozen" Gutter Leak cougar01 Roofing/Siding 19 02-10-2009 06:07 AM
