Old 10-01-2009, 04:40 PM   #1
join poured concrete wall to CMU wall?
Is is possible to make a retaining wall that is a combination of poured concrete and cmu?
Because of an odd size and limited area, I'd like to make one section using poured concrete now, and join it to a cmu wall at a corner in the future. Is that possible using rebar and filling the core with mortar?
p.s. Thanks for the answers in my related post on joining slabs.
walkman is offline   Reply With Quote
Old 10-01-2009, 09:17 PM   #2
of course ! deform'd rebar works fine,,, you'll always have a joint where they abut,,, most important's the drainage system behind the wall & the strength of the footer,,, think we need permits here over 4' - haven't run into the stamp'd plans rqmts yet, tho,,, fill w/grout over conc.
wouldn't retaining wall blocks work better for you ? ? ?
itsreallyconc is offline   Reply With Quote
How to seal a shower pan liner against a concrete foundation wall? mgray87 Kitchen & Bath Remodeling 3 08-13-2009 12:08 PM
Brick wall - concrete slab floor separation. DewmanTN General Discussion 5 07-24-2009 10:57 PM
Concrete wall replaced with stick frame? jackpine Building & Construction 12 09-03-2008 05:15 PM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 10:52 PM
Basement Ceiling Drywall- ? When wall is concrete H Thomas Building & Construction 5 04-20-2006 10:20 AM
