#1 |
Jigsaw Tile Blade?
I bought a jigsaw tile blade (Bosch from lowes for 8 bucks) Is it worth a darn? I just need to cut three holes - tub spout, mixer, and shower head. If its not good after cutting the holes the fine. One hole is 3/4", the other is 3" and the last is 1 1/4".
Before suggesting, I've already tried to rearrange tile trust me and the size of the tile doesn't work to put the grout line in the middle of the cut outs. Any better ways than a jigsaw? I have a great dewalt jigsaw thats pretty powerful. I take it I should wet the blade too? |
#2 | |
Jigsaw Tile Blade?Quote:
Ron |
#3 |
Totally screwed together
Jigsaw Tile Blade?
I used a diamond jigsaw on some cuts, a little larger than yours.
I plugged my jigsaw int a GCFI outlet I did the work in a water filled pan, with the work hled up on wood blocks and the water level just below the workpiece. The blade would pull up a little water with every cut to keep the blade cool, and I worked slow and easy. Keeping your hands wet will keep you from getting glass shard slivers too. |
| Display Modes | |
| Tile over Tile ?? | Piney | Flooring | 17 | 02-06-2012 10:59 PM |
| Re-tiling a bathtub surround | BillyB44 | Remodeling | 39 | 01-24-2011 07:10 PM |
| Trimming installed tile with tile blade in normal circular saw? | jdraughn | Tools | 5 | 12-13-2009 10:07 PM |
| Some questions about laying Tile? | DiY_RooK | Flooring | 1 | 08-31-2007 10:35 PM |
| Tile and laminate, or get rid of tile? | kfoster | Flooring | 10 | 03-17-2006 03:14 PM |
