Jet Black Floor Joists With Creote-like Substance? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2014, 11:19 AM   #1
Jet Black Floor Joists with Creote-like substance?
We live in a 2-story Georgian (w/ basement) built in the early 1950s.
We recently discovered a busted drain pipe running thru an interior soffit in our Kitchen. The plumber suggested it was a longstanding problem (many years) even though we just started noticing any evidence of the problem (water leaking into the kitchen thru the wall/soffit).
When the plumber opened up the soffit to replace the pipe we noticed that the underside of the floor above the kitchen and the floor joists were jet black - almost if they had been sprayed with something.
At first, from a distance, we also thought there was a significant amount of black mold, however, upon looking closer, it looked more like the creosote buildup you might find in a chimney. In some sections, it looked almost like it was 1/2 inch to 1 inch thick.
The plumber thought it might be insulation sprayed with some sort of black tar.
Any thoughts on what it could be? Harmful?
(I apologize for not having photos to share at the moment)
Rocks1 is offline   Reply With Quote
Old 01-22-2014, 12:07 PM   #2
joed's Avatar
Rewards Points: 13,728
Never heard of black spray insulation. Could it have been the remains of a past fire?
I think if it was creosote you would smell it. What is it like if you scape it? hard? soft? black all the way through or painted spray foam? Can you post a picture?
Old 01-22-2014, 04:52 PM   #3
Rewards Points: 626
start checking for insect damage. that sounds like what wood looks like after capenter ants or termites come over for dinner.
Nailbags is offline   Reply With Quote
Old 01-22-2014, 07:40 PM   #4
Rewards Points: 14,306
There would be no reason for creosote on a second floor.
And it would never be that thick, it was just a brushed on coating.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Tankless - Black Soot Problem BillGrayslake General DIY Discussions 0 04-13-2013 01:02 PM
Grout color for black and white wall tile mix Andiy Tiling, ceramics, marble 3 02-21-2013 09:15 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Black Iron Exposed? jamiedolan Plumbing 0 08-14-2009 10:16 AM
