Jamb Meets Casing... Is It Necessary To Have A Reveal? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-26-2013, 09:31 PM   #1
Rewards Points: 31
Jamb meets casing... Is it necessary to have a reveal?
My house has a modern look to it, and as I am about to start trimming out doors I have recently installed, I was wondering if it is necessary to leave a reveal on the jamb where it meets the casing, i.e. have zero reveal.
Any thoughts are appreciated. Thanks!
domh is offline   Reply With Quote
Old 10-26-2013, 09:46 PM   #2
iminaquagmire's Avatar
Rewards Points: 338
It is customary to have one, but no, it is not necessary. However on your interior side, you may need clearance for the barrels of your hinges.
iminaquagmire is offline   Reply With Quote
The Following 2 Users Say Thank You to iminaquagmire For This Useful Post:
domh (10-27-2013), oh'mike (10-26-2013)
Old 10-27-2013, 08:37 AM   #3
Rewards Points: 3,130
To me, trim without a reveal just looks "wrong." But if you have added some doors, I'd think you'd want their trim to match the rest of the house, however it is done.
The Following User Says Thank You to md2lgyk For This Useful Post:
domh (10-27-2013)
Old 10-27-2013, 10:21 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,006
yes, if its not it creates a line that will show up in the paint and look horrible even more so if its not perfectly flush all the way around
it creates a shadow line which makes it look like its supposed to be there just make sure you keep it consistant all the way around and from one window to the next.
also on doors if the casing is flush it will cause the leafs on the hinges to rub restricting hte doors ability to swing freely, this becomes even worse when using thick casings
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
domh (10-27-2013)
Old 10-27-2013, 11:10 AM   #5
Rewards Points: 31
Ahhh, yes. I knew there was a good reason... Thanks for the heads up!
Old 10-27-2013, 02:27 PM   #6
In a little over my head
Rewards Points: 706
Before I knew better, I trimmed out a large window in our living room with no reveal. It looks OK. No one has ever looked at it and said "That looks bad. Where's the reveal?" Years later, I trimmed a set of french doors at the other end of the same room. Same molding, with a proper reveal. It looks better.
ratherbefishing is offline   Reply With Quote
Bullnose drywall casing meets backsplash conspikuous Tiling, ceramics, marble 3 02-07-2012 11:50 AM
Gap in door jamb and casing MarcW Carpentry 7 07-09-2011 11:37 PM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 10:24 AM
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 04:13 PM
Oak casing to a vinyl jamb extension on a new window? Dustball Carpentry 13 04-14-2010 12:06 PM
