-   -   Jacuzzi Whirlpool bath floor construction (http://www.diychatroom.com/f19/jacuzzi-whirlpool-bath-floor-construction-63360/)
eemc2 02-01-2010 03:54 PM
I am installing a Jacuzzi Whirlpool corner bath. It is about 60"x60" and according to the documentation, filled can be 984lbs or 39lb/sqft. How do I provide the support required for this weight. How should the floor be constructed?
Mike
clasact 02-02-2010 08:21 AM
you will need to supply more info like where it will be at 1st floor second ? what do you have to start with concret slab or wood floor joists? Your question is pretty broad with out a few details
eemc2 02-02-2010 09:20 AM
My apologies, I should have provided more information.
It is a second floor bathroom. I am completely gutting it, including the subfloor. I have 2"x8" joists, 16" OC. I am not sure of the unsupported span yet, I have to check, however there is a room directly below and I believe the tub is partially over a corner of the room, so there should be some support from two walls below on the first floor. The joists, are probably regular pine (not I-joists).
HTH
Mike
ccarlisle 02-02-2010 09:31 AM
Look, it's quite possible that some engineer would come in, do the load math and find that your joists are just fine the way they are... on the other hand, since your almost there anyway, why not play it cool and sister the joists while you have access to them? It may just be wht the engineering studies will tell you in any case...
I may be wrong and your particular floor the exception to the rule, but we normally sister joists just for new stone tiles on the floor, let alone a whirlpool tub. What's a few joists, two guys and a few hours?
Beer's optional.:laughing:
eemc2 02-02-2010 09:44 AM
Forgive my ignorance, but by 'sister' I assume you mean just double up perhaps supported on ends by blocking extending under the tub? I plan on possibly laying about 1 1/8" of plywood on the floor as well. Are nails good enough for the sistering or should I be using screws to double them up?
tpolk 02-02-2010 11:43 AM
unless the walls under the 2x8 are structural/bearing they do not count as helping in load transfer. i think depending on span 2x8 is undersize for load. you need someone to put an eye on it to be safe and not have tub end up on first floor
eemc2 02-03-2010 10:14 AM
Thanks for the responses.
How far would I have to extend sistered joists to make them beneficial? Could I just sister directly under the tub? I could possibly sister some 2x12's, thus raising the tub a few inches but there would be 2x12's for support?
Mike
