Jackposts - Temporary Or Permanent? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2008, 03:59 PM   #1
drh
Question
Jackposts - temporary or permanent?
Recently, while demolishing an old basement, I came across two jackposts which had been drywalled and hidden from view. They are the classic telescoping posts with the pin pushed through the middle to determine the height. These two posts hold the primary structure of the home (there are two), and rest on concrete pads (see attached pictures).
Before I close up the drywall, I would like to ask whether this style of jackpost is safe to use as permanent supports to the house? Or whether I should be investigating having some form of single steel column put in their place?
Any advice would be appreciated. Thanks in advance.
.drh
Jackposts - temporary or permanent?-img_3520.jpg   Jackposts - temporary or permanent?-img_3521.jpg
drh is offline   Reply With Quote
Old 02-05-2008, 09:40 AM   #2
waiting for spring
arichard21's Avatar
Rewards Points: 150
I can tell ya right now that outlet doesn't meet code. I am sure that duct tape isn't a perminant installation!
arichard21 is offline   Reply With Quote
Can floor jacks in basement be permanent? ragtopdave06 Remodeling 15 03-15-2007 05:23 PM
Temporary power... MLO Electrical 8 02-18-2007 11:43 PM
