Jacking Up A Sagging Breakfast Nook - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-21-2008, 06:20 PM   #1
Jacking up a sagging breakfast nook
I have a breakfast nook that is sagging about a quarter to a half an inch out of square particularly on the left side facing the nook on the outside of the house. What is the simplest way to jack up and stabilize this minor drop prior to replacing the windows in the nook?
Thomas Stillwell is offline   Reply With Quote
Old 09-21-2008, 08:38 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
check the sill plates and floor beams to see if there is any rot or termite damage.
If you could post a picture we will be able to help you better, there could be something going on ,on the left side. BOB
Old 09-21-2008, 08:47 PM   #3
Registered User
Termite's Avatar
You need to determine if it is wood rot or termite damage like Bob said, or if there is a foundation problem.
Wanting Tips on Jacking a sagging floor beam andrewcocke Remodeling 5 02-10-2008 08:24 PM
sagging roof and ceiling randys Roofing/Siding 4 03-13-2007 07:21 PM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 04:16 PM
