Old 02-08-2010, 07:08 PM   #1
Jacking up a house
I have an older 1 1/2 story house with a rock wall and need to raise it up 18". I want to place jacks in the cellar but need to something to put them on. the floor to ceiling distance is about 7 feet. I am interested in seeing a diagram, picture or explanation of the crib work to set the jacks on. I want to find something inexpensive to build the crib work from and was thinking of railroad ties but these are replaced by the railroad when they are getting towards the end of their life for supporting a train and don't know if they would be strong enough for this use.
Renovate is offline   Reply With Quote
Old 02-08-2010, 07:15 PM   #2
Remodeling Contractor
Jacking up a house
they are strong enough but pressure treated 6X6s are better. Why? square and even edges to prevent them rolling over during the lift. Use bottle jacks and 4X4 posts or pole jacks. Be sure whatever you use is perfectly level in all directions. Lift slowly and evenly to prevent cracks throughout the house. Lift only 1/4" and wait to allow the house to settle again.
Old 02-08-2010, 07:34 PM   #3
firehawkmph's Avatar
Jacking up a house
Reno,
This is one of those jobs where I think you would be wise to talk to a house moving crew in your area and see what they want to lift the house for you.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-08-2010, 07:42 PM   #4
Jacking up a house
plus even the old ties down here weigh a ton
The older I get the better I was
Old 02-08-2010, 07:43 PM   #5
Jacking up a house
I'm with Mike Hawkins on this one---I've helped jack some amazing weight,as a millwright.
We always used oak or steel---I've seen concrete fail under the stress of high point loads.
Pine as cribbing in the hands of a novice would make me want to run. --Mike--
Old 02-08-2010, 08:30 PM   #6
Man of many hats
wrangler's Avatar
Jacking up a house
Was reading this post and just had to ask... is lifting a house 18" a common thing or even safe? Just seems that a house that is has sunk that far would have all kinds of problems ( plumbing, doors, even electrical?) Would the structure itself in relationship to the wall joints be sound?
Just curious....
Brett
Man of many hats
wrangler is offline   Reply With Quote
Old 02-08-2010, 09:43 PM   #7
Jacking up a house
A lot of the older houses had shallow cellars. As long as the house is being lifted to build a modern foundation--Why not life it up to a more usable height?
Quite common.--Mike--
Old 02-08-2010, 09:46 PM   #8
Extreme DIY Homeowner
Scuba_Dave's Avatar
Jacking up a house
Whats the floor space of the 1st floor...dimensions of house ?
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/-ongoing-37438/
Please fill out Location in your profile (User CP), then we can answer your question
If a code reference is needed for one of my posts please access NEC 2008 & read
http://nfpaweb3.gvpi.net/rrserver/browser?title=/NFPASTD/7008SB
Scuba_Dave is online now   Reply With Quote
Old 02-08-2010, 10:34 PM   #9
General Contractor
Jacking up a house
Not really your typical diy job.
I would love to see photos if you manage to pull it off!
Good luck,
Rory
RDG Read Development LLC
Portland, OR
Rory Read is offline   Reply With Quote
Old 02-09-2010, 02:43 AM   #10
jlhaslip's Avatar
Jacking up a house
House Movers have access to all sorts of trick stuff, like self-levelling hydraulic lifting systems, Engineers and experience.
The greatest wealth is to live content with little, for there is never want where the mind is satisfied.
-Lucretius
jlhaslip is offline   Reply With Quote
Old 02-09-2010, 08:07 AM   #11
Jacking up a house
To answer some of the above questions.
No it is not a DIY job. Normally I would have 8 people lifting in unison. Radio controlled jacks. It must be done perfectly level and very slowly with time allowed between lifts.
No it is not common. What is common is raising the entire roof to add a second level to cape style houses. This saves the roof costs and reduces time the house is exposed to the weather. The time to get this covered is about 12 hours.
Old 02-09-2010, 08:10 AM   #12
Scuba_Dave's Avatar
Jacking up a house
Definitely not DIY unless it is a VERY small house
Even the Pro's will sweat it out as the house is lifted & supported
I have seen quite a few houses jacked up to have a proper foundation poured
One a storm came in & blew the house off the supports, destroying the house
More On This Topic
A scissor jack is a primary tool used when changing motorcycle tires; learn how to use one in this video on DIY motorcycle maintenance for flat tires. Read More »
A wine cellar is an incredible addition to any home, providing a place to store your prized wines as well as host wine-tasting events for your friends and family. Creating an elegant wine cellar can be a huge endeavor, but you don't need to have an... Read More »
Today we're talking about different Christmas celebrations from around the world. Well in Malta, the Christmas celebration, the tradition basically is centered on a crib; a crib for the baby Jesus. Every home has one. Just about every Christian home has... Read More »
On behalf of Expert Village, my name is Bob Lanning and I’m here to tell you about how we’re making model villages. Now to get information on how to do all this, there’s two or three good magazines, Model Railroader has been around for... Read More »
So after we’ve kind of come up with an idea of colors that the client likes or that you like yourself out of your artwork, one of the things that I like to do is go to the paint store and buy paint chips and then create a diagram of the space. It... Read More »
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 14 01-18-2010 08:52 PM
Jacking up house! Ineedhelp2009 Building & Construction 2 06-06-2009 04:40 PM
replumbing an old house simonfrog Plumbing 5 05-29-2009 06:44 PM
Wanting Tips on Jacking a sagging floor beam andrewcocke Remodeling 5 02-10-2008 09:24 PM
Connecting main house to guest house... hlavine Building & Construction 27 01-18-2008 11:24 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
