Old 06-06-2009, 11:29 AM   #1
Jacking up house!
A few months ago I jacked up my whole house 1.5" I had a big post on here with alot of help.
One corner of my house roughly a 6' span accross the pour wall I jacked it about 1/8-1/4 to high. The french doors around that corner are a little off. But still shut fine also a new crack in second floor ceiling showed up. Along with a few more new cracks in the walls..... Is that enough to leave alone or should I jack house back up on that corner and take a shim out? I used 1/8 and 1/4 metal shims on solid concrete blocks. So i do not see much room for settling. I hate to keep moving the house around. But if needed I will do it.
Ineedhelp2009 is offline   Reply With Quote
Old 06-06-2009, 04:17 PM   #2
Jacking up house!
The cracks showed up as a result of the movement. It's easier to reposition the door than jack the house up again. Easier on both you and the house.
Ron
Old 06-06-2009, 04:40 PM   #3
Jacking up house!
Ron
Thanks... well the good part alot of the big cracks on one side closed up
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
My new project, 31 year old house... Axhammer General Discussion 3 04-08-2009 09:46 AM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
