-   -   Jacking up house! (http://www.diychatroom.com/f19/jacking-up-house-46071/)
Ineedhelp2009 06-06-2009 10:29 AM
Jacking up house!
A few months ago I jacked up my whole house 1.5" I had a big post on here with alot of help.
One corner of my house roughly a 6' span accross the pour wall I jacked it about 1/8-1/4 to high. The french doors around that corner are a little off. But still shut fine also a new crack in second floor ceiling showed up. Along with a few more new cracks in the walls..... Is that enough to leave alone or should I jack house back up on that corner and take a shim out? I used 1/8 and 1/4 metal shims on solid concrete blocks. So i do not see much room for settling. I hate to keep moving the house around. But if needed I will do it.
Ron6519 06-06-2009 03:17 PM
The cracks showed up as a result of the movement. It's easier to reposition the door than jack the house up again. Easier on both you and the house.
Ron
Ineedhelp2009 06-06-2009 03:40 PM
Ron
Thanks... well the good part alot of the big cracks on one side closed up :thumbsup:
