Jack Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2007, 07:40 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Jack Studs
I'm going to install a 4x10 header for a 66" RO (entryway door). I need to remove two studs to expand the current opening.
Centering the new door between the remaining studs leaves me with 2 1/2" on one side and 4 1/2" on the other.
I would have liked to support the header with at least 2-2x4s on each side but with only 2.5" on the short side I would need to either:
- move the existing stud over to make more room
- plane one of the 2x4s down to 1"
- make sure that the stud is as plumb as it can possibly be and push the door right up on the stud.
Do I need two full 2x4 jack studs to support the header?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-04-2007, 10:44 PM   #2
Rewards Points: 5,336
If you want 2-2x4's under each side, do it. Rework the R.O. so you can. I don't think you need to for 66". I would add blocking under the subfloor so the load is transferred directly to the sill plate and foundation. Unless you're on a slab.
Ron
Old 09-04-2007, 11:13 PM   #3
Center it perfectly. You sound like my wife. Do you really think you will notice a whole 1/2 inch off perfect center. Trust me you will not notice ( O.K. if you notice no one else on the planet will).
warnerww is offline   Reply With Quote
Old 09-05-2007, 06:35 AM   #4
I have gas!
You're probably right, our current door is 3/4" off center and I didn't notice until now. I am my own worst critic though.
I don't want make extra work for myself so if I don't need to move that stud, I don't want to. There's blocking in the stud bay that would need to be trimmed back so it's not as simple as just knocking out the top and bottom and adding a new stud.
Old 09-05-2007, 10:30 AM   #5
I have gas!
I guess I only need 1 jack stud per side to support the header. I don't know how I got into my head that I needed 2 per side.
Old 09-05-2007, 12:03 PM   #6
One on each side is enough. Centering it would be more work but if it is that important to you then have at it. Most people ( I believe ) would not worry about it.
Old 09-05-2007, 08:28 PM   #7
remodeling pro
One jack per side will do for support. I would only worry about the perfect centering if the width of the door fits very closely between walls. If so the uneven reveal between the door trim and the adjacent walls, or the possibility that the trim on one side may have to ripped will be pretty obvious. If there is at least a foot to any adjacent walls, this slight off enter position will never be noticed by the average person. But once you have the header supported with a jack under each end, you can use any thickness "fillers" you want to position the door, they do not have to be symmetrical. Remember, this is a "rough" opening, you want to have at least 1/2" of space on each side of the door unit for squaring it in the hole.
troubleseeker is offline   Reply With Quote
Old 09-06-2007, 06:10 AM   #8
I have gas!
Thanks everyone.
I was concerned about centering the door in the portico. 2 studs would have pushed it 1/2" over to one side, 1 stud is no problem.
Phone/Fax Wall Jack cmgith Electrical 5 04-18-2009 11:21 PM
Advice on Enlarging a Door Opening WorkOnIt Carpentry 9 02-04-2007 11:53 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
Need to Jack up part of my house.... harleysilo Remodeling 24 10-01-2006 08:05 AM
How to line up trusses with studs aero_ub Carpentry 5 04-24-2006 03:48 PM
