Old 09-16-2012, 08:49 PM   #1
jack stud split
In photo, above top right hinge the jack stud is split. Door opens and closes fine. Not sure if I am mistaken and that it is actually a king stud. Up close, several checks in the wood where the stud split. Smooth cut at top of stud.
FYI- I am the one that removed the drywall to get a better picture of what was going on.
sacseven is offline   Reply With Quote
Old 09-16-2012, 09:09 PM   #2
jack stud split
Not seeing a split in that picture.
What went on that would make you check this out?
To me something looks off, that stud looks to close to the jamb. There should have been a jack stud then the king stud.
Is there a header?
Old 09-16-2012, 09:50 PM   #3
jack stud split
The door was sticking and the trim was slightly bowed, the drywall was cracked. I assumed something was making the door stick so I took out the drywall to see the wood behind it. The stud is 100% for sure split.
After doing all this, I noticed it was the ADT security sensor was the cause. Took that off, door opens and closes fine.
king stud, jack stud holes .. beachfront71 Building & Construction 5 04-22-2012 12:38 PM
Adding phone jack simbey1982 Electrical 22 01-17-2012 05:40 PM
1 or 2 jack studs? NCgranny Building & Construction 8 03-22-2010 11:17 AM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
2 outlets sharing a stud and also telephone jack? LeviDIY Electrical 9 09-02-2009 10:24 AM
