Jack Stud For Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 10:25 PM   #1
Rewards Points: 1,584
Jack stud for door
I have a situation where I need to put in a jack stud for a door. Only problem is the bottom plate was cut flushed with the king stud, so the jack stud have to make contact with the concrete slab.
Should I use PT lumber for the entire jack stud? I am not sure attaching a small piece of PT 2x4 at the bottom makes a lot of sense.
miamicuse is offline   Reply With Quote
Old 06-26-2013, 11:03 PM   #2
General Contractor
CENTERLINE MV's Avatar
SPF is fine. Throw a little piece of lead, aluminum, copper, etc... If you're concerned. Is this an interior door?
CENTERLINE MV is offline   Reply With Quote
Old 06-27-2013, 12:24 AM   #3
Yes, interior door.
Old 06-28-2013, 08:37 AM   #4
AHH, SPANS!!!
Rewards Points: 1,166
I'd use a treated stud there along with galvanized screws/nails and a dab of liquid nails where the jack hits the concrete floor...
hand drive is offline   Reply With Quote
Old 06-28-2013, 05:51 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
You could use a redwood 2x4 for the trimmer.
It is naturally insect and decay resistant and is to code.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
woodworkbykirk (06-28-2013)
Old 06-28-2013, 05:55 PM   #6
Framing Contractor
Rewards Points: 74
If the jack is non bearing, just leave it short of the floor by 1/2" or so.
sixeightten is offline   Reply With Quote
jack stud split sacseven Building & Construction 2 09-16-2012 09:50 PM
king stud, jack stud holes .. beachfront71 Building & Construction 5 04-22-2012 12:38 PM
1 or 2 jack studs? NCgranny Building & Construction 8 03-22-2010 11:17 AM
Moving a Stud HooKooDooKu Building & Construction 5 02-23-2010 02:11 AM
2 outlets sharing a stud and also telephone jack? LeviDIY Electrical 9 09-02-2009 10:24 AM
