-   -   Jack stud for door (http://www.diychatroom.com/f19/jack-stud-door-182569/)
miamicuse 06-26-2013 10:25 PM
Jack stud for door
3 Attachment(s)
I have a situation where I need to put in a jack stud for a door. Only problem is the bottom plate was cut flushed with the king stud, so the jack stud have to make contact with the concrete slab.
Should I use PT lumber for the entire jack stud? I am not sure attaching a small piece of PT 2x4 at the bottom makes a lot of sense.
CENTERLINE MV 06-26-2013 11:03 PM
SPF is fine. Throw a little piece of lead, aluminum, copper, etc... If you're concerned. Is this an interior door?
miamicuse 06-27-2013 12:24 AM
3 Attachment(s)
Yes, interior door.
hand drive 06-28-2013 08:37 AM
I'd use a treated stud there along with galvanized screws/nails and a dab of liquid nails where the jack hits the concrete floor...
AndyGump 06-28-2013 05:51 PM
You could use a redwood 2x4 for the trimmer.
It is naturally insect and decay resistant and is to code.
Andy.
sixeightten 06-28-2013 05:55 PM
If the jack is non bearing, just leave it short of the floor by 1/2" or so.
