Jack Post Spacing In Basement - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 05:25 PM   #16
Rewards Points: 2,212
Tarheel it could be a regional thing but we use "Jack Posts" or "teleposts" all the time for permanent installation.
We have moved them, called for changes in the wood beam, wasn't even that big a deal Just added a 2x10 on each side of existing beam in our case I've also heard of adding metal plates to the sides of the beam. And dug a new footing.
We did not add 2 just moved the one and changed the beam.
mae-ling is offline   Reply With Quote
Old 07-07-2012, 06:29 PM   #17
MarginallyQualified
Rewards Points: 2,464
Truly? They let that slide ?
A lally column is a solid steel tube/pipe with concrete in it set permanently.
A jack post (like a jack) has moving parts to raise it.
Old 07-07-2012, 06:54 PM   #18
Civil Engineer
Rewards Points: 4,862
The critical question with jack posts versus lally columns is whether the jack post is rated for permanent use. Some of them are, but you have to check with the manufacturer, because I believe most of them are rated for temporary use only. However, this is a detail that is beyond many inspectors. For example, my house has to jack posts in the basement, and two lally columns, all of which are load bearing. Been that way since 1959. Who knows what the rules were back then.
As for moving the existing jack post or lally column, whichever it may be, the OPS has stated that the existing post is NOT TOUCHING the beam. If that is in fact the case, the post cannot be carrying any load, unless you believe that spooky action at a distance quantum mechanics applies to lally columns. It may be that the post is actually needed, but was not installed correctly. Could also be that the post is not in fact necessary. This would be a call for the engineer to make.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
GBrackins (07-07-2012), Mjclemm (07-08-2012)
Old 07-07-2012, 08:50 PM   #19
Originally Posted by GBrackins View Post
steel columns under steel beams are normally welded all around to the beam. At least that's how I've done them the past thirty years.
Good luck MJ, let us know what the engineer says.
Thanks, that's what I had thought, what made me even think about moving it was 2 things, it wasn't welded, and it doesn't touch the I beam.mi will let ya know what they say.. Thanks again... Mjclemm...
Mjclemm is offline   Reply With Quote
Old 07-07-2012, 09:08 PM   #20
GBrackins's Avatar
Rewards Points: 2,108
You are most welcomed.
I'm certain we would all enjoy your update. too many times we have posts that we never hear the results of. can also help to confirm advice that is given, or dispel it.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 3 Users Say Thank You to GBrackins For This Useful Post:
drtbk4ever (07-09-2012), mae-ling (07-08-2012), Mjclemm (07-08-2012)
Old 07-08-2012, 12:32 AM   #21
Originally Posted by TarheelTerp View Post
No... they are Lally (or Lolly) columns.
Jack posts are a different crittrer and areused solely for temporary uses.
4inches 4 feet 4 yards... you don't "move" them.
if you plan to replace one... then also plan to add two.
I stand corrected, thanks for the correct term to be using, the pole in this case would be a "Lally" column. Also, the 4' is for 4 feet. Just another question, have you ever seen a "Lally" that wasn't touching the I beam? Mine is approximently 1/16" short of the ibeam. I find it strang, the house was built in the 1980s in Wisconsin... Must be in the cheese..lol.l thanks again. I will refer the the post in question as a "Lally" post from here out.. Mjclemm
Old 07-08-2012, 09:59 AM   #22
AHH, SPANS!!!
Rewards Points: 1,166
maybe the floor/footing the post is set on settled some and the beam stayed where it was causing the space between the two. it might take years for the beam to settle down to the post but it may never, who knows for sure?
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
Old 07-08-2012, 10:14 AM   #23
MarginallyQualified
Originally Posted by Mjclemm View Post
...have you ever seen a "Lally" that wasn't touching the I beam? Mine is approximently 1/16" short of the ibeam. I find it strange...
We're back to assumptions...
1) the current column placement was calculated properly
2) the installer dropped the ball (no weld)
3) changing the PLACEMENT of the column opens you up to all manner of
issues not lease being inspection requiring 2012 standards.
If you weren't remodeling I'd suggest that you get a piece of 16ga steel to shim the gap and weld the column/beam joint. If you're plan is still to remove the column... the replacement(s) better be set in the right spot(s) and with a proper foundation.
How "right" gets determined usually involves an engineer. But as said before, a plan to replace one column with two (because of span issues) might be the safest bet.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 07-08-2012, 10:34 AM   #24
Tele-posts here are rated for permanent use and have the advantage of being adjustable, so if your house shifts you can adjust them as needed.
The Following User Says Thank You to mae-ling For This Useful Post:
Old 07-09-2012, 01:29 PM   #25
column
I would agree with the other posts, consult an engineer.
As for the jack post, code states that the column must be at 3" in diameter.
R407.3 Structural requirements. The columns shall be restrained to prevent lateral displacement at the bottom end. Wood columns shall not be less in nominal size than 4 inches by 4 inches (102 mm by 102 mm). Steel columns shall not be less than 3-inch-diameter (76 mm) Schedule 40 pipe manufactured in accordance with ASTM A 53 Grade B or approvedequivalent.
You can get more info at www.DeanColumn.com
DeanColumn1 is offline   Reply With Quote
Old 07-09-2012, 01:35 PM   #26
GBrackins's Avatar
You are correct in Section R407.3, but so that others understand, the 3" schedule 40 steel pipe column has an outside diameter of 3-1/2", the inside diameter is 3".
Gary
Reuse Concrete Fence Post Pier & Fence Post Extraction JasonCA Landscaping & Lawn Care 2 03-24-2012 08:58 PM
build around a post jack warmar Carpentry 5 08-23-2011 08:18 AM
how to get power to lamp post from basement BlueBSH Electrical 4 08-18-2011 05:19 PM
