Jack Instead Of Post In Basement--adjusting? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-23-2013, 11:46 PM   #1
Rewards Points: 71
Jack instead of post in basement--adjusting?
I know this is a jack; it looks like they cut out a post a long time ago, back in the '40s, while doing some remodeling in the basement. There's another one on the other side of that wall, too. Looks like the jacks and the bricks are holding up a joint between two halves of the big beam.
I'm just wondering: Do I ever need to adjust this thing, and how would I do it safely? I just had 10 tons of roofing removed from a 16-square roof, so our house just had some major weight-reduction surgery...
El Barbón is offline   Reply With Quote
Old 12-24-2013, 06:51 AM   #2
Rewards Points: 13,296
Not even sure why that lolly column is even there.
The end of that beam should of had a footing and jacks or some form of brick and or block fully supporting it on the ends, no lolly needed.
Makes me wonder if someone removed them from mid span someplace where they where supposed to be.
Reducing the weight on the roof should have no or little effect where the post is sitting.
Old 12-24-2013, 08:28 AM   #3
joed's Avatar
Rewards Points: 12,002
That is not a jack. It is a standard adjustable lolly column. No need to adjust it once it has been set.
Old 12-24-2013, 09:56 AM   #4
Rewards Points: 6,652
Only if the floor is dropping, then you would adjust that jack. Post a picture of the bottom of the post, showing if it is embedded in the concrete of the floor or not.
I am guessing that they had some settling on that end, due to water and aging of the structure, and figured that would fix it.
build around a post jack warmar Carpentry 5 08-23-2011 09:18 AM
how to get power to lamp post from basement BlueBSH Electrical 4 08-18-2011 06:19 PM
Basement Metal Support Post virgolibranyc Building & Construction 4 09-07-2010 04:07 PM
wooden basement post rotten on bottom truckinkat Building & Construction 1 09-29-2008 06:35 AM
