J Channel Around Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2008, 10:22 AM   #1
Question
I am putting Vinyl Siding on an addition. The windows I have installed have a channel built in. Can I use this for my vinyl or do I still need to install the J trim?
EADPellCity is offline   Reply With Quote
Old 06-12-2008, 11:19 AM   #2
Another DIY Zombie
Rewards Points: 264
I have seen it done both ways. My pref is to use the built in channel, as it is cleaner, but I have seen others do it by installing another channel around the window (looks quite ugly in my opinion)
javan is offline   Reply With Quote
Old 06-12-2008, 01:15 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Using the built in J channel will be more weather tight than having another seam for water to enter.
Old 06-12-2008, 08:56 PM   #4
remodeling pro
That is exactly what it is designed for. Be vigilant about sealing the window flange to the wall.
troubleseeker is offline   Reply With Quote
Old 07-06-2008, 09:06 PM   #5
Not to hijack your post,but I too am in the process of an addition with windows with a built in j channel. Do you have to add some kind of flashing at the top to stop rain from getting between siding and housewrap? Thanks in advance!!
Kenny Borel is offline   Reply With Quote
Old 07-06-2008, 10:14 PM   #6
Think I found the info I was looking for.
Old 07-07-2008, 04:04 AM   #7
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
http://www.albertsroofing.com/Window%20Flashing.htm
tinner666 is offline   Reply With Quote
Old 07-07-2008, 05:48 AM   #8
That's the article I found. Thanks!!
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 06:32 PM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
