Im doing a very different style small vinyl job (not on side of home)and will be attatching j channel back to back on studs.Is there a technique or cut to make on both to get the backs to notch together(will be nailed in to stud through the slots ).Like maybe a open grove cut in inside edges on both.
Need a bit more hold than just regular nailing in groves as when usually hung.
Have you ever installed J over the top of a window? If so then you know how to make one piece with a tab and the other one will have a slot, but the faces will look the same length.
I wont be working with ends at all with this part of it ,just the 2 long outsides.Maybe some kind of notching would work to hold the backs of the 2 long outer edges together ..
What is it your really trying to do? Why not just use H molding instead of two differant pieces.
Your missing my point, if you knew how to trim out a winodw with J molding you would know what I was talking about when making a tab.
On each end one piece will be cut at the inside corners at a slight angle to form a tab. The other piece gets the same cut but the whole piece gets remove. Put the two together and just bend over the tab to hold the two together. http://www.arcat.com/details/view_detail.htm?co=alsides&detail=07460030&coid=30321
For what I am doing that won't work..its nothing like a window trim project . Not an outside house project either.
Again its not something that H will work for.
I will try the v grove method for it..along the inside every 16 inches..
Just wanted best cut method for inside attachment(not a typical project)
If your not willing to tell us what it is your trying to really do then your on your own.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
