J Bolt Anchor In Concrete Footer, How To Make Even And Level? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 10:41 AM   #1
Rewards Points: 115
J bolt anchor in concrete footer, how to make even and level?
Hello everyone,
I'm in the planning stages of my deck build. I am planning for 4 12" diameter concrete footers with bigfoot system pads, and 6x6 posts. For post to concrete connection I will be using Simpson Strongtie ABW66Z.
After I pour the concrete (I'm probably having a truck come, no mixing ourselves), my questions are:
1) About how long do I have immediately after pouring the concrete to set in the J bolts before the concrete gets too hard to set them in? I was thinking about 30 minutes from some research I've done?
2) What is the best/easiest way to keep the J bolt in the same position level and straight vertical in the wet concrete until it dries?
3) Is there a J bolt to use for this application that is better than others?
Thanks for any experience and advice you can provide!
6fthook is offline   Reply With Quote
Old 08-11-2012, 10:57 AM   #2
Civil Engineer
Rewards Points: 4,568
I usually set my J bolts as soon as the concrete is stiff enough to support them, which is often less than 30 minutes, depending on temperature. The simplest way to get it set right is to install the J bolt and the bracket at the same time, with a nut to hold the J bolt onto the bracket. It is usually easy to get the bracket in the right place, and the J bolt goes with it. Not really important if the J bolt is perfectly plumb, only thing that really counts is that it is deep enough in the concrete, and the top of the bolt lines up correctly with the bracket, which of course it will if you set them together.
Old 08-12-2012, 12:32 AM   #3
Rewards Points: 13,300
To tired and messing up
Old 08-12-2012, 12:58 AM   #4
Framing Contractor
Originally Posted by joecaption
No offence but I would never ever suggest a DIY try and pore there own slab unless it was a really small one.
A slab is a one shot deal, if it's not preped right, formed right, finsihed right, there's no going back and fixing it.
When that truck rolls everone there have to know what there doing and when to do it.
Look over this site and any DIY site and see dozens of people dealing with cracking, pored to low, pored to high, or water pooling on the decks.
Joe,
He's not doing a slab. He's talking about footings for a deck.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-12-2012, 11:53 AM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
You can set them in there as soon as you've troweled it to the finish you want. You don't want the concrete to get too hard, otherwise you'll have voids right around your J-bolt, which kinda defeats the purpose. I see a lot of guys nail grade stakes to the top of their forms and tie the J-bolt to it with some bailing wire, that works too.
Mort is online now   Reply With Quote
Old 08-12-2012, 03:24 PM   #6
Haverhill Trade 1965
That should work for the cardboard tubes too.
Duckweather is offline   Reply With Quote
Old 08-13-2012, 10:13 AM   #7
Mort's Avatar
Rewards Points: 690
Yup, that's how we pour light poles. Same idea.
