IRC 404 Basement Walls Lateral Support? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2007, 01:06 PM   #1
IRC 404 Basement walls lateral support?
Any thoughts or comments on IRC 404. I've not seen it yet, I need to get the new code book. Are there methods other than Simpson proprietary brackets. Simpson site suggest their bracket system takes up top support for the lateral load of the backfill. I'm thinking maybe there's practical blocking or other nonproprietary method. What are you builders doing with this? Thanks bjr23
bjr23 is offline   Reply With Quote
Old 07-25-2007, 06:11 PM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Are you talking about the rediculous changes in anchor bolt spacing requirements that were made a standard for all walls because of the need in the weaker panels systems (segmented, non cantilevered) like AWWF and Superior?
Some code provisions have be eliminated in some jurisdictions and I suspect some jurisdiction may put off complete adoption for a while.
I do not have my 2006 IRC handy, so if this is not the item, please respond.
concretemasonry is offline   Reply With Quote
Old 07-26-2007, 10:07 AM   #3
I've not seen it yet either
I just read about a new L shaped bracket in the Simpson New Products site and it mentioned the 404 code. The new bracket is used with their anchor bolt natuarly. It looks like you connect the bracket to the joist or on to the rim joist and bolt thru the sill plate. Otherwise just the toenails from the joist hold the house to the sill plate. bjr23
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Required support for wiring in walls? leonsphinx Electrical 5 02-23-2007 07:25 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
"floating" basement walls? greg s Carpentry 2 03-04-2005 08:56 PM
