-   -   IRC 404 Basement walls lateral support? (http://www.diychatroom.com/f19/irc-404-basement-walls-lateral-support-10157/)
bjr23 07-25-2007 12:06 PM
Any thoughts or comments on IRC 404. I've not seen it yet, I need to get the new code book. Are there methods other than Simpson proprietary brackets. Simpson site suggest their bracket system takes up top support for the lateral load of the backfill. I'm thinking maybe there's practical blocking or other nonproprietary method. What are you builders doing with this? Thanks bjr23
concretemasonry 07-25-2007 05:11 PM
Are you talking about the rediculous changes in anchor bolt spacing requirements that were made a standard for all walls because of the need in the weaker panels systems (segmented, non cantilevered) like AWWF and Superior?
Some code provisions have be eliminated in some jurisdictions and I suspect some jurisdiction may put off complete adoption for a while.
I do not have my 2006 IRC handy, so if this is not the item, please respond.
bjr23 07-26-2007 09:07 AM
I've not seen it yet either
I just read about a new L shaped bracket in the Simpson New Products site and it mentioned the 404 code. The new bracket is used with their anchor bolt natuarly. It looks like you connect the bracket to the joist or on to the rim joist and bolt thru the sill plate. Otherwise just the toenails from the joist hold the house to the sill plate. bjr23
