Ipe Screw Spacings From Sides - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-18-2009, 12:41 AM   #1
dIYHell
Rewards Points: 150
ipe screw spacings from sides
Installing an IPE deck on 16" centers and face screwing #8 Stainless steel predrilling and countersinking before. I am putting the screws 1/2" from the side is this too close? Just started to putting boards down so trying to decide if I should change this pattern before I get too far.
rocketdoctor is offline   Reply With Quote
Old 10-18-2009, 07:55 AM   #2
I would look into the hidden fastener systems. There are at least several that work well. Why put holes in that expensive wood.
Old 10-18-2009, 08:26 AM   #3
dIYHell
Rewards Points: 150
couple reasons why I don't use hidden fasteners. Almost everyone Ive talked to and every posts I read say don't use them for IPE they don't work well and won't prevent warping. The other reason is I actually like the industrial look of the Stainless Steel fasteners . Of course the most ithe important reasons I am comitted Ive already started to layboards down and would like a second opinion on the spacing before I finish.
Old 10-18-2009, 09:03 AM   #4
Not so new
12penny's Avatar
Rewards Points: 520
rocket....i'd come in a little. 1" should be okay. I face screwed my last one, but I counterbored and installed plugs. 2000 or so all together.
Hidden fasteners are okay. Used them too, but you can still see them between the boards.
12penny is offline   Reply With Quote
Old 10-18-2009, 09:44 AM   #5
Knucklez's Avatar
Rewards Points: 930
i am prepping for a deck job next spring and have read 3 books from the library on the subject. each book talks about hidden fasteners and each book did not recommend their use.
would avoid them; that is unless there are NEW products on the market that are much more reliable.
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 02:56 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
