IPE Decking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 08:09 AM   #1
IPE decking
I am investigating the use of IPE decking for a deck I am going to build. I've doen soem research ont eh internet and it appears that IPE is better than most locally sourced woods and composites. But, I can not find any lumber yards locally that say they can get the stuff.
Any idea where I can find IPE in the Cleveland area or even order it from and have it shipped here?
EPERRINGTON is offline   Reply With Quote
Old 04-05-2011, 09:21 AM   #2
IPE decking
Since I have never used IPE before. Anyone have insight into the best way to install/protect, etc.
When I have researched on the internet there seems to be lots of information that contradicts itself.
Help.
Old 04-05-2011, 09:46 AM   #3
Not so new
12penny's Avatar
Rewards Points: 520
....dont know where to get it in Cleveland. Search lumberyards in your area and start making phone calls. Somebody has to be able to get it.
....I've installed Ipe a variety of ways. I've used Ipe clips, which are a hidden fastener system, and I have also counterbored the face of the board for screws and then plugged the holes with Ipe plugs. I think face screwing and plugging is a more solid install but you can tell it has plugs in it.
....and you'll need a chopsaw with a new blade, maybe 2 depending on the size of your deck. Use a product called Anchor Seal on all fresh crosscuts to prevent checking.
....Only used one sealer on Ipe and that is Messemers UV Protectant for Hardwoods. Brings out the beauty and has some UV inhibitors.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
EPERRINGTON (04-05-2011)
Old 04-05-2011, 10:09 AM   #4
IPE Decking
Thanks for the info. Your deck looks awesome! How long have you had your deck? Have you benn happy with it? What type of yearly maintenance do you have to do to it? I read that when you initally install you are supposed to coat all sides of the board (with Mezzers or something else). Is this what you did?
Old 04-05-2011, 10:25 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
....not mine. Belongs to a customer. Been up for about 4 years now and havent received any negative feedback. And yes, sealed all around except for crosscuts.
Old 04-05-2011, 11:44 AM   #6
IPE decking
As I have been researching I have come across some other foreign woods such as tigerwood.
Does anyone have any experience with this wood or others that they would recommend or care to coice Do's and Don'ts or Pro's and Con's?
Old 04-05-2011, 11:47 AM   #7
IPE Decking
12 penny....
Does the coating need to be applied on all surfaces every time? What frequency? I am looking at placing on a deck that would be about 24" above ground and by the time you put joices under neath I am not sure I want to be crawlling under that. I'm not claustrophobic....but I might be after that job!!!
Old 04-06-2011, 07:40 AM   #8
Not so new
12penny's Avatar
Rewards Points: 520
....no. You only have to do the tops after the first year.
Old 04-06-2011, 07:47 AM   #9
kwikfishron's Avatar
Rewards Points: 86
I think the plugs add character myself.
kwikfishron is online now   Reply With Quote
Old 04-06-2011, 08:33 AM   #10
Not so new
12penny's Avatar
Rewards Points: 520
yeah...it didnt look bad. And it gives it a different look. Not to noticeable.
1700 plugs though.
Didnt know you could buy them at the time.
Went thru 3 plug cutters.
Old 04-06-2011, 05:11 PM   #11
Rewards Points: 86
1700 plugs though.
Thatís a lot of plugs, I just do the ends, rails, etc. and hide everything else.
Didnít know you could buy them, Iíll remember that.
Dang Reps, Their suppose to push that stuff on you whether you want it or not.
Trex decking LL1 General DIY Discussions 56 09-30-2011 10:55 PM
Deckmaster--will it work with 3/4" hardwood decking? jbeall Building & Construction 8 03-15-2011 10:05 AM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 07:16 PM
Decking Michael Avram Building & Construction 2 05-26-2008 08:24 PM
Plastic decking? kcrossley2 Building & Construction 4 10-08-2007 11:59 AM
