Old 07-31-2008, 01:03 AM   #1
Ipe deck boards on concrete pads
My sister and brother-in law want me to put Ipe decking boards 3/4" thick on concrete pads with decrotive pebbels in them. Ive heard about using preassure treated sleepers on the pads then putting the deck boards on top of the sleepers any ideas about this would be really helpful thanks.
duncan wood butcher is offline   Reply With Quote
Old 07-31-2008, 08:55 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
What is this going to be used for, Walk way? Patio?. what is with the block with the deco stones in them. is this something that they want to see when the decking is installed. treated lumber is the way to go. Unless your making some sort of duck walk. then you could use the decking material its self.(if its going to be removable ). Bob
Old 07-31-2008, 09:37 AM   #3
You should call the guys at IpeDepot.com, they are very knowledgable about Ipe. You need to be careful befor putting Ipe to close to concrete becuase of the moisture content in concrete.
hardwood_decks is offline   Reply With Quote
Old 07-31-2008, 09:59 AM   #4
Moderator
Termite's Avatar
This was done by a contractor at Union Station in Kansas City. They used treated sleepers, and were careful to space the deck boards a little more than usual to promote air flow under the floor.
My biggest concern would be lack of airflow and whether or not the concrete is pitched enough to shed water.
reversing deck boards deck hand General Discussion 26 11-01-2010 11:07 AM
Sagging concrete pool deck Immolate General Discussion 1 06-11-2008 10:16 PM
deck header over concrete steps and other deck questions bobcatnj Building & Construction 6 05-09-2008 03:54 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 09:01 AM
Cedar Deck boards Outbacker Painting 2 03-04-2006 02:12 PM
