Ionart - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-14-2010, 12:53 PM   #1
ionart
I recently replaced the rat slab with a proper steel reinforced slab in my late 1940's Sausalito home. I'm planning to put in a wood floor over a sub floor constructed of PT sleepers and 3/4" PT plywood. PT plywood is very wet (21%). Is it inadvisable to use or can it be dried out sufficiently with dehumidifiers.
I have also been advised to use 3/4" bamboo flooring for the finished floor because it's more stable than maple.
Please share your thoughts, keeping in mind that my location is a high moisture area.
ionart is offline   Reply With Quote
Old 08-15-2010, 09:51 PM   #2
Registered User
Rewards Points: 5,232
Welcome to the forum!
http://www.buildingscience.com/docum...ms?full_view=1
Be safe, Gary
Gary in WA is online now   Reply With Quote
Tags
bamboo vs maple flooring? , dehumid 2 dry pt plywood? , how to dry pt plywood? , is bamboo stable? , pt plywood as subfloor?
