Interpretation Required - Trench Depth - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 12:27 AM   #1
Rewards Points: 518
Interpretation required - trench depth
I'm allowed to run natural gas and electrical in the same trench according to the city as long as I comply to the following:
- Natural gas line must be at a minimum depth of 15"
- PVC conduit must be at a minimum depth of 18"
- 12" of separation required between the two
Does this mean I need to dig approximately 29" deep, run the PVC, backfill to around 15", run the gas line, and maintain the separation vertically then back fill again OR:
Dig a whole 18" deep, run the two parallel just a foot apart and maintain separation horizontally?
n0c7 is offline   Reply With Quote
Old 08-21-2011, 05:56 AM   #2
Rewards Points: 1,512
Either way will do.
Old 08-21-2011, 06:50 AM   #3
I think they mean horizontally, but don't take my word for it, check with the local authority.
Old 08-21-2011, 07:31 AM   #4
Framing Contractor
How come you are not asking them ?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-21-2011, 08:34 AM   #5
Rewards Points: 518
They don't know themselves. Gas guy says not my problem I need 15" ask the electrical guy. Electrical guy says he doesn't know ask the gas guy. I found the information digging myself.
Old 08-21-2011, 03:08 PM   #6
Think about the guy digging it up in the future. What would you want if you were the electrical guy? I'd want them separated horizontally so I don't have to expose the gas line to work on electrical. Separate them more than the minimum if you can since you really don't want to hit either accidentally.
bleedpurple is offline   Reply With Quote
Old 08-21-2011, 04:13 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
THAT is a common sense answer. If you already have the trencher....its really not that much more work to do two trenches.
Drain Tile Trench dnt Flooring 1 04-12-2011 03:11 PM
backfill & grass over a gravel trench ??? linboomer Landscaping & Lawn Care 4 05-09-2009 06:54 AM
opinions wanted on foundation trench sketch annie68164 Building & Construction 12 03-05-2009 11:38 AM
replace basement or dig trench w/tile? annie68164 Building & Construction 3 02-19-2009 06:17 AM
What would be the required wood screw depth for mounting? cdpage Home Theater 4 10-24-2008 12:22 PM
