Internal Gutters - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2011, 04:22 PM   #16
Agressive DIY
Originally Posted by DexterII View Post
The reason that I mentioned the structure was that you said these would be run "inside the wood framed wall". To me, is seems that in order to get inside the wall, you would have to breach the top and bottom plates, which are an intregal part of the structure. I know that such gutter systems exist, as I have seen them, and I assume that it is not much of a problem on a new build, but it seems that it could present a whole other set of issues on a retrofit. Was just throwing it out for consideration.
Thank you very much, DexterII, for elaborating on this. I can clearly see your point now. The entire house has metal beams around the perimiter going from foundation all the way to the roof, so I don't think this will impact the structure much. But I will run this by a structural engineer. Thank you for bringing this up!
deeonline is offline   Reply With Quote
Gutters and Decorative Trim on Fascia paulyg Roofing/Siding 12 07-27-2010 02:54 PM
new drip edge over existing gutters scheiman Roofing/Siding 1 06-05-2010 07:44 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 08:25 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 12:42 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 09:36 PM
