-   -   interlock paver for driveway (http://www.diychatroom.com/f19/interlock-paver-driveway-114736/)
albertkao 08-20-2011 09:16 PM
I am researching interlock paver for my (double-car-width) driveway.
Is the larger and thicker the paver the better in terms of stability, durability, etc?
ie. 80 x 300 x 450 mm is better than 70 x 300 x 300 mm?
Which one is better - 80 x 300 x 450 mm or 80 x 400 x 400 mm?
Ron6519 08-20-2011 10:38 PM
The success of a paver driveway lies more in a proper base.
concretemasonry 08-21-2011 10:51 AM
The width and length of those units do not qualify as true structural interlocking pavers because there are too wide and long. They appear to be "stepping stone" type products. Because of the ratio of the width or length to the thickness, the larger units can crack and be difficult to install properly and carry the loads.
The 80 mm thickness interlocking paving stone is used commonly for driveways and some streets. For a patio, 60 mm thickness can be acceptable and 100 mm is used for airport taxiways and heavy duty industrial sites like ship cargo unloading ports and storage areas for containers.
Usually, a true interlocking paver is no more the about 10" (250 mm) in either length and width, but commonly 8" or 9".
When you used the term "interlock paver" were you referring to the name of a single manufacturer (Interlock) that makes both stepping stones true interlocking pavers or for the general product type?
The key to the great strength of an interlocking paving stone installation is the base compaction and proper installation methods. > a compacted base > a uniform 1"(maximum) uncompacted clean sand setting bed > true interlocking paving stones set tightly in an interlocking pattern > fine sand sprinkled on the pavers > vibration with a vibratory plate vibrator to work the sand down into and up into the tight joints and to make the surface even.
The interlocking pavers are made to a minimum strength of 8000 psi, with 10,000psi+ very common. Usually the stepping stones do not have a minimum ASTM requirement for strength.
There are some minor differences in the strength of an interlocking pavement for different shapes AND laying patterns, but they are not major factors unless the pattern is a "stacked" pattern.
For installation and technical information, go to the Interlocking Concrete Paving Institute (ICPI) at icpi.org (I think). The installation and technology is common to most countries, but is generally based on European methods where the products were developed many decades ago and came to the U.S. in about 1970.
Dick
albertkao 08-22-2011 08:53 PM
I refers to for the general product type
nicksab 08-22-2011 09:48 PM
I agree with this. It doesn t matter the size of the pavers you use.
The critical part in interlocking paver is the preparation of the base and also on your drainage underneath if any.
P.S: just make sure you use a good geotextile fabric.
jackpercy57 08-23-2011 04:26 AM
http://www.amovos.info/ccamazon1.jpg
http://www.amovos.info/cc2.jpg
http://www.amovos.info/cc3.jpg
