Interior Wall Sills On Cement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 10:52 PM   #1
Interior Wall Sills on Cement
We are putting an addition on our home in Missouri. The addition is on a cement slab. My husband built the interior walls and did not use pressure treated wood for sills or put a sill sealer underneath. Is this ok? The exterior walls have pt sills and sill sealer. If this is not ok, how do we fix it? Would a liquid sealer fix the problem if there is one?
melanie1620 is offline   Reply With Quote
Old 04-09-2012, 11:02 PM   #2
Rewards Points: 12,856
Little late now to ask, not much you can do about it.
Should be fine.
Old 04-09-2012, 11:24 PM   #3
cortell's Avatar
Rewards Points: 504
Joe, she's talking about an interior wall
cortell is offline   Reply With Quote
Old 04-09-2012, 11:45 PM   #4
Got ya, I fixed it.
Old 04-11-2012, 12:39 AM   #5
Registered User
Rewards Points: 4,924
Since it's a new addition, including the slab, there should have been a vapor barrier poly plastic between the earth and concrete, as per minimum Code. Otherwise, any underground water could find its way to your new concrete through capillary action and wick into any wood touching it. That is the whole idea for the code-required poly (preventing extra moisture in the framing/living space. The sill sealer also acts as a thermal break from the warmed frame wall to cold concrete/earth = heat sink, robbing you of warmth already paid for.
If framed but not drywalled, add a poly or similar under the wall only if no v.b. was installed before concrete was poured.The inspector would have looked for that..... Some may say- "I checked for moisture by taping poly down on top the slab, none was present". In that 2' by 2' small area, in that particular season- not after a rain, etc.
Live and learn: http://www.greenbuildingadvisor.com/...-building-code
The poly is important, Figs. 6-9: http://www.buildingscience.com/docum...sture-problems
If poly was added, ignore this post...
Gary
Old 04-11-2012, 11:54 AM   #6
Work Hard, Play Harder
Rewards Points: 212
Gary
Not intending to hijack; but what do you do on an older home where you know this break is missing? (all beams sitting on foundation directly)
coderguy is offline   Reply With Quote
Old 04-11-2012, 02:00 PM   #7
cortell's Avatar
Rewards Points: 504
...and the bottom plate of an interior wall isn't PT (not sure what you mean by "beams" here)?
If the wall is finished (drywall is up), there's nothing simple you can do. Hope for the best. If it's not load-bearing, replacing it in the future is straight forward. If it's load bearing, not so much. The problem is there's no way to know for sure that it will be a problem. Maybe the slab will have minimal moisture and that plate won't rot for 20 years. Maybe the slab will have a lot of moisture and it'll turn into a big issue in two years. One thing you can do is remove the baseboards every couple of years and, assuming there's a gap below the sheetrock, check the plate for signs of mold/rot. No signs, no worries (for now). Of course, removing baseboards and properly reinstalling them may involve some work.
Old 04-11-2012, 11:27 PM   #8
Registered User
With your beams/joists sitting directly on the concrete wall, they are linked to any wetness from below. If the concrete is very dense, rather than very porous, capillary water wicking is reduced. There is no way to tell, other than checking on it periodically. Be certain the down-spouts are extended/directed away from the wall, and surface grading is such to prevent excessive water there. If they are not rotted by now, they should be fine, unless other things I mentioned change that.
have my joists shrunk ?
Gary
Old 04-12-2012, 09:08 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 824
This thread illustrates how building science is a constantly changing and improving field.
We have been building houses on concrete for how long now? And it's only recently that the vapor barrier was required?
My house was built in the 50's....earthquake country. It has lived this long....but the sismic steps I am having to do now vs 50 years ago....drastic difference. My neighbor (Lou 93 year old retired engineer) is astonished at how stout I'm building everything. But even he agrees that while what we did 50 years ago was 'good enough', nothing wrong with doing it better.
I do know that if the big one hits....my house will still be standing....b!itch is not going anywhere.
ddawg16 is online now   Reply With Quote
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 06:30 PM
Moisture Barrier Behind AND on Top of Cement Board JasonCA Remodeling 0 04-07-2012 02:31 PM
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 08:08 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
