Interior Wall Pass-through Window Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2011, 03:58 PM   #1
Rewards Points: 4,796
Interior wall pass-through window framing
Not sure which forum.... assuming this is a non-load bearing wall, I'm not sure what frame is required for a small pass-through window. Are jack studs required? Or even an entire frame for the pass-through? In other words, can the bottom sill plate simply be nailed onto the bottom cripple studs and toe-nailed into the full side studs, and the same on the top? It doesn't seem the wall really needs to support anything, after all. That seems pretty flimsy though.
jeffnc is offline   Reply With Quote
Old 04-01-2011, 04:27 PM   #2
kwikfishron's Avatar
Rewards Points: 1,006
Welcome to the forum.
You frame the opening just as you would a window.
If the wall is non-bearing than a 2x header is fine.
If the wall is bearing then you need to have someone figure out the load and size the header accordingly.
kwikfishron is online now   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
window performance question renbelle Building & Construction 4 10-06-2010 02:25 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 09:33 AM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
