Interior Wall Framing Nails Question. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2010, 08:24 AM   #1
the Musigician
DangerMouse's Avatar
Interior wall framing nails question.
Can someone please post the irc section that specifies acceptable nail sizes and types (twist, ringshank, etc.) for interior and exterior wall framing?
Thanks!
DM
Old 07-22-2010, 08:02 PM   #2
the Musigician
Oh come on.... SOMEone has to know this....
I have a box of 8D FRAMING NAILS and would like to know why they call them framing nails if you cannot frame with them....
Simple 2x4 walls guys..... what size nails? what type(s) are accepted?????
DM
Old 07-22-2010, 08:14 PM   #3
jlhaslip's Avatar
Rewards Points: 2,864
I use 3 1/4 inch Phosphorus coated nails inside or out for hand nailing framing, but I am Canadian and don't know what an 8 penny nail is...
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 07-22-2010, 08:18 PM   #4
the Musigician
That still leaves an inch of nail under the plywood waiting to give me a lobotomy when I lift my head up doing work in the crawl space....
DM
Old 07-22-2010, 10:20 PM   #5
Registered User
Rewards Points: 526
Here's an old one from an old one: http://www.mcvicker.com/resguide/page014.htm
Be safe, Gary
Old 07-23-2010, 06:51 AM   #6
the Musigician
Thanks Gary! That's what I was looking for, and it actually loaded for me too! LOL
DM
Old 07-23-2010, 10:16 PM   #7
Rewards Points: 1,910
ESR 1539
Heres a link that has a copy
http://www.paslode.com/uploadedFiles/ESR-1539.pdf
The Following User Says Thank You to jogr For This Useful Post:
Gary in WA (07-24-2010)
Old 07-24-2010, 04:00 PM   #8
Tizzer's Avatar
Rewards Points: 466
I can't remember ever using a real 16D for anything. They required a higher end framing gun just to shoot them.
Always used 3 1/4 .131 nails(12) for regular framing and 2 1/2(8s) ringshanks for floor & roof sheathing. Mostly screwed the floor down, tho.
Tizzer is offline   Reply With Quote
Old 07-24-2010, 05:36 PM   #9
the Musigician
What's a "framing gun"? Some newfangled hammer?
DM
Old 07-24-2010, 05:39 PM   #10
the Musigician
It'd sure be better with 'example' pictures....
Is there an "Illustrated basic framing guide for Dummies" book out there? LOL
DM
Old 07-24-2010, 06:04 PM   #11
kwikfishron's Avatar
Rewards Points: 998
There’s only been 2-3 different boxes of nails on any framing job I’ve ever done.
16d for framing and 8d for sheathing and a box of roofing nails if gyprock/fire rock is involved (apartments, hotels, etc.).
Oh ya, I forgot my friend Teco.
kwikfishron is online now   Reply With Quote
Old 07-24-2010, 06:17 PM   #12
Framing Contractor
We use 8d's for toenailing studs and 10d's for shoes/plate and the rest of the framing. Decking and sheathing we use 8d ringshank.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-24-2010, 06:17 PM   #13
the Musigician
A 3 1/2" nail seems to be dumb to me if an inch of it sticks under the flooring into dead air. (and then in my friggin skull) a 2x4 on the 3/4" floor leaves too much nail on the other side. SOMEone please explain to me why it is necessary to endanger myself to pass code? Or IS it code? SHOW ME THE PICTURES!!! lol
What's the smallest nail I can use to nail a 2x4 to a plywood floor? So it DOESN'T poke through the other side?
Is this making sense????
DM
Old 07-24-2010, 06:44 PM   #14
Rewards Points: 998
Wow, framing with 10s, never heard of such a thing. I guess itís a location thing.
Donít get into the ring shanks until siding.
That would be Wood Siding by the way, we still use it out West.
Old 07-25-2010, 01:00 PM   #15
Tizzer's Avatar
Rewards Points: 466
Your supposed to hit joists with the nails. A joist is usually planned to be underneath most walls. Walls running perpendculiar(sp?) only get nailed through the joists. Small walls that can't be nailed like that, well - the nails just go through the plywood.
Use a 10 or 12 for those. The inspector isn't gonna crawl under there and look at what nails you used....... but you didn't hear that from me.
question of wall framing feralfreak Building & Construction 23 04-12-2011 07:42 PM
floor framing question wengang1 Building & Construction 9 04-19-2010 07:30 PM
Above grade framing and a few framing question jreed Building & Construction 6 01-16-2010 10:56 AM
Stair framing question stubborn1 Carpentry 6 01-18-2009 11:12 PM
Framing detail question bernie Building & Construction 7 11-16-2007 08:20 PM
