Interior Partition Wall Perpendicular To Floor Joists/open Cathedral Rafters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 11:01 AM   #1
Interior Partition Wall perpendicular to floor joists/open cathedral rafters
I have a open cathedral ceiling with the rafters exposed. Iím using non-stamped/structural 2x4s.
The issue that Iím having is a method that my building inspector wants for how the top plate attaches to the rafters? I was thinking about using a single top plate, then ripping a second top plate that matches the slope of the roof/rafters.
Will that fly with the inspector?
Thanks for any help.
Thebentdude is offline   Reply With Quote
Old 10-30-2011, 11:34 AM   #2
Rewards Points: 5,336
This is a question I would ask the inspector. Any opinions voiced here are useless.
Are you going to do all that work based on internet advice?
I don't think the inspector will be swayed with the,"But Ron on the internet said it was okay" arguement.
But it will give him a chuckle.
Ron
B. Franklin 1759
Old 10-30-2011, 11:41 AM   #3
I'm just wondering if there is actually a standardized method for this. I've done rake walls before, but this is totally different, it's going perp instead.
I'm going through the timber framing section of the CBC, and I can't find anything.
Oh yeah, in CA too.
Old 10-30-2011, 11:59 AM   #4
Oh yeah, in CA too.
Standard and California are mutually exclusive terms, even without the earthquake thing.
Why the reticence to talk to the inspector?
Ron
B. Franklin 1759
Old 10-30-2011, 12:36 PM   #5
I'd just like to start it early. Regardless, I'll give him a call tomorrow morning and see if he has any input.
If anyone else has had this situation, please feel free to post your outcome.
Old 11-01-2011, 01:58 PM   #6
The purpose for a dbl top plate is to transfer loads from stud to stud. If I read this correctly you can't "birds mouth " the roof framing hence the notion of a ripped top plate to provide bearing support. There is likely a mechanical fastener for this. Alternatively use a dbl top plate and rip down a third but in any event speak to your inspector first if you intend on departing from conventional construction.
Marvel is offline   Reply With Quote
Old 11-01-2011, 04:53 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,010
so this is a partition and not a bearing wall by the sounds of things. . is the exposed ceiling paint grade or stain grade.. just trying to think of a way to fasten the top plate first so you have something to measure to.
definitely ask the inspector, if its only a partition the one concern i can see coming up is making sure any fasteners used dont penetrate through the sheathing then into the roofing material.
it can be glue but you also need to have the studs cut first and to a snug fit so to create resistance while the glue sets up
woodworkbykirk is online now   Reply With Quote
Tags
cathedral ceiling , interior wall
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 09:22 AM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
rafters pushing the wall out christy123 Building & Construction 70 12-10-2006 08:59 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
