-   -   interior load bearing walls with a heated slab? (http://www.diychatroom.com/f19/interior-load-bearing-walls-heated-slab-66762/)
forresth 03-14-2010 05:25 PM
I am planning a house with radiant heat floors on a slab. my plan it to have 2 interior walls to be load bearing. do I need to put footings under them, or just make sure there are no heat pipes under them? or something in between?
Bob Mariani 03-14-2010 08:02 PM
load bearing walls need a footing.
jlhaslip 03-15-2010 01:23 AM
place the interior walls on footings and then add the radiant heat around them.
jomama45 03-15-2010 09:35 AM
Are you doing a "shallow, frost protected slab", or a frost wall with floor?
I would guess the latter, especially with heated floors in your climate. If so, you can either pour a concrete footing at the same time as the frost footings (which is the simpler approach IMO) and set a 1/2 course, 4" CMU block for the wall, OR pour a thickened, re-enforced grade beam into the floor under the wall location.
forresth 03-15-2010 12:21 PM
I think your sugested was about what I was thinking. I may tweak it some.
