Interior French Drain Cement Necessary - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 04:19 PM   #1
Rewards Points: 14
Hello.
I am having an interior French Drain installed in my Crawl Space due to water issues. The contractor will dig out the drain, place in PVC with holes, add stones around the PVC, etc.
He said I can leave it alone with the stone or cement over it. There is an extra charge to cement over the stone.
Is there a reason to choose one way or another? I have never seen a French Drain which has not been cemented over.
Thanks for the help.
Bob
bern8277 is offline   Reply With Quote
Old 10-27-2010, 11:06 PM   #2
Civil Engineer
Rewards Points: 4,952
The only reason for covering a French drain with concrete is if you plan to walk on the surface. Else you can simply fill to grade with stone. Make sure your contractor surrounds the perforated pipe with filter fabric to reduce the potential for silt to clog the pipe.
Daniel Holzman is online now   Reply With Quote
Old 10-28-2010, 01:31 AM   #3
Rewards Points: 978
i would advise against the french drain. best solution is to fix the cause not treat teh symptom
federer is offline   Reply With Quote
Old 10-28-2010, 10:06 PM   #4
Rewards Points: 4,800
dan's correct on both points as is federer,,, however, this is not a perfect world,,, if it were, barney frank wouldn't have been reelected 5 terms ago
Old 10-31-2010, 10:27 AM   #5
Rewards Points: 14
Thanks for the reply
Thank you to everyone who has replied. I appreciate the comments and thoughts.
Old 10-31-2010, 03:16 PM   #6
Concrete & Masonry
Rewards Points: 636
The biggest benefit to pouring a concrete floor in a crawlspace would be to protect the vapor barrier.
jomama45 is offline   Reply With Quote
float cement around floor drain n2learning Flooring 1 09-13-2010 08:14 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
HELP! Cement in PVC drain pipe KAT Plumbing 7 05-18-2006 07:17 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
