Old 05-22-2008, 04:13 PM   #1
Question Interior Doors before Sheetrock?
We are constructing our own home and are currently installing all electrical outlets and lights. We were told that interior doors are to be installed before sheetrock. Does anyone know which order to do this step? We have our doors.
mtmkgirl is offline   Reply With Quote
Old 05-22-2008, 04:22 PM   #2
I usually don't like to sound condescending, but if you don't know what order the drywall and doors go in, I would be very careful if you are doing the elecrtic yourselves. If you have pre-hung interior doors, they will go up after the drywall is hung and finished.
jerryh3 is offline   Reply With Quote
Old 05-22-2008, 04:32 PM   #3
Well you can take a look at our photo album, we have done everything ourselves so far. From footings, foam block basement, framing, subfloor, roof, attics, plumbing, and now we are doing the electrical. My husband was a laborer before being a heavy equipment operator. He is very handy at building anything. We have chosen not to do the insulation and sheetrock ourselves since we can pay someone and still come in under budget. We haven't spoken to the guy that is doing the sheetrock yet, but we have gotten conflicting reports on when to put interior doors in.
Old 05-22-2008, 04:40 PM   #4
Underground Techie
sevver's Avatar
I put the doors in after the drywall. Put up the drywall, right over the rough opening, and cut it out while it is hung. I use a rotozip to cut it. Congrats on doing everything yourself, that is the only way. For a DIY forum there seems to be alot of opinion against actually doing it yourself. Electrical is so complicated after all.
You can put the doors in before you finish the drywall if you want, but the sanding dust will just get on them.
sevver is offline   Reply With Quote
Old 05-22-2008, 04:40 PM   #5
Looks nice. I didn't mean anything by the response, but sometimes doing it yourself and doing it the right way don't always match. Who told you to put the door up before the drywall? And, did they give a reason?
Old 05-22-2008, 04:44 PM   #6
Thank you so much. We are have a great time. We have been married 20 years and most people think this is the toughest thing a married couple goes through, but we just made a decision when we started that it was going to be fun! You will have to check out our photo album on here.
Old 05-22-2008, 04:44 PM   #7
Underground Techie
sevver's Avatar
Whoever said that is a bit dense I would say. You need the drywall up first so that you have something to align the edge of the door frame with when you install it.
Old 05-22-2008, 04:56 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Interior doors are not installed before drywall as a general practice. Even if the frames are installed and the doors slabs removed, the possibility of damaged door frames, and door frames covered with joint compound are extremely high. I Would not advise doing so.
- Build Well -
Old 05-22-2008, 05:21 PM   #9
Put me down for drywall before interior doors too. BTW, the house and view look great.
Old 05-22-2008, 05:37 PM   #10
Default Wow, Thank You
It is nice to get advice from people that have actually done this. Insulation and sheetrock are 2 things we didn't want to do ourselves. Our cabinets arrive June 18th, so we have to get busy the next 2 weeks!
Old 05-22-2008, 05:54 PM   #11
Building codes guy, Mod
thekctermite's Avatar
I agree too! Never a good idea to install doors before sheetrock, even if they aren't pre-hung units. Ever watch a sheetrock crew work? Those doors will be covered in dust, mud, tape, sweat, dents from falling rock, and used ketchup packets in no time!!!
thekctermite is offline   Reply With Quote
Old 05-22-2008, 11:33 PM   #12
BUILDER / REMODELING CONT
buletbob's Avatar
I agree with all the above ,
but, if your installing drywall no by all means drywall first ,doors second,
but if you plastering, hang the doors first set jambs, then removed doors and hinges, this way the plaster can use the jamb to float his top coat flat and flush with the jambs. BOB
Old 05-23-2008, 03:05 PM   #13
Same boat here, but only married 18 years. Having fun with rebuilding our house. Here's a slightly different twist on the doors:
For our finish we opted to bull nose the drywall into to the door frames (no casing). I'm sure there is a more accurate term. Our interior jambs were custom cut to 3-1/2" with a kerf. With these I found it easier to install the doors first then rock up to the jamb to get close enough for the bull nose kerf. You can cover some gap with the bull nose but not as much as you can with casing.
Other than that, I would agree with the "doors after" in order to protect them.
steve1234 is offline   Reply With Quote
Tags
interior doors, sheetrock
More On This Topic
Learn how to refinish and interior door jamb, including sanding and painting, in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Detailing your vehicle is an important step to maintaining the car's condition and value. If corrosion, residue and other gunk is allowed to build up on the working components of your vehicle, they can lead to malfunctions in the parts. This is true for... Read More »
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Now we're going to talk a little bit about spackling on a door jamb. Now, earlier we talked about spackling walls. Now interior or exterior walls... Read More »
How to Caulk Trim
How to Caulk Trim by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter. And today I represent expertvillage.com. Okay now we're going to talk a little bit about caulking interior door jambs. Now, this is very different from anything else you caulk, Now this is... Read More »
Learn how to caulk when refinishing door jamb in this free house remodeling video from an expert finish carpenter and experienced home inspector. Read More »
Sheetrock question Vengence Remodeling 4 07-13-2007 12:42 PM
Sheetrock nightmare MRZ Painting 12 05-25-2007 11:23 PM
Reparing sheetrock abelsu Painting 8 02-23-2007 11:41 AM
Need Sheetrock repair advice Giterdone Carpentry 6 02-03-2007 10:38 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
