Old 01-01-2010, 05:04 PM   #1
Interior Basement Wall finishing
I have a sixty year old house that has a 7' high basement on one side, and a 3' high crawlspace on the other. in between is a poured concrete wall. This basement has never been (properly) finished. In particular, the wall between basement and (unheated) crawlspace has never been finished. I want to frame and drywall this wall but don't know if I need a vapour barrier or insulation. Will condensation occur the same as a true exterior wall, or would the temperature in the crawlspace be constant enough to prevent this? For my exterior walls I am using rigid polystyrene/tape/studs/drywall.
tookie is offline   Reply With Quote
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
