Interior Basement Door Under A Low Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-25-2015, 06:43 PM   #1
Rewards Points: 14
Interior basement door under a low ceiling
I'm in the process of building a storage room in a basement that has very low ceilings--the ceiling clearance where I'm putting the wall is no higher than 77". Would the best bet to be to accept that I can't really have a door here, just a opening?
Scott_R is offline   Reply With Quote
Old 03-25-2015, 06:48 PM   #2
Rewards Points: 12,794
Buy a real wood prehung door and you can cut down the door and jamb.
May even be able to buy one made for a mobile home that's shorter.
Old 03-25-2015, 07:28 PM   #3
Rewards Points: 2,202
Joe gives a good suggestion.
You can also cut down a hollow core door. http://www.finehomebuilding.com/item...door-to-height.
Also consider not having a top jamb, just the two sides. Gains you another inch or more of height. But some may consider it odd. If you do have a top jamb then use really narrow casing across the top.
mae-ling is offline   Reply With Quote
Old 03-25-2015, 07:53 PM   #4
Rewards Points: 14
"Real wood" as in not hollow? I was going to use steel studs/track for the wall. Should I have the top track run across as a sort-of header?
Old 03-25-2015, 09:06 PM   #5
Yep he suggesting a solid door.
I usually do not recommend steel track in a basement and definitely not on the bottom. They tend to rust out, but it is done. Make sure you use wood studs on the sides of the door opening to attach the door frame to.
No need for the top track to run across, just fasten wall solidly on both sides of door opening. If you want you can fasten the door stop strip across the top to the ceiling, but not needed, just a design/ looks thing maybe.
Old 03-25-2015, 09:13 PM   #6
Rewards Points: 14
Yes, I was going to do a pressure-treated wood base, with a barrier between it and the steel track (since you're not supposed to put steel track directly on pressure treated wood).
The Following User Says Thank You to Scott_R For This Useful Post:
mae-ling (03-25-2015)
Old 03-26-2015, 08:46 AM   #7
Rewards Points: 314
The ceiling joist is not holy. You can cut it or notch it for necessity and convenience - as long as adding to the joist or supporting it replaces the capacity of that joist. For example, the hallway to the door can have higher ceiling with notched joist and additional narrower joists or sistering to it. New supporting wall and/or posts and headers will take up the load.
Just an idea.
carpdad is offline   Reply With Quote
Old 03-26-2015, 10:35 AM   #8
If you put posts in as suggested above you also need footings under those posts.
Old 03-29-2015, 12:07 AM   #9
Rewards Points: 314
Sorry about the door question.
Make your door with 1x6, although you may not want it as rustic.
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 05:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
