Interior Balcony Railing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 08:11 PM   #1
Standard balcony railing height requirements are 36". Is this a minimum? If railing height is 1-3/4" or 2-1/2" do I need to cut 36" balusters down?
bgarski is offline   Reply With Quote
Old 03-05-2013, 08:22 PM   #2
recently retired
Rewards Points: 270
it can go all the way to the ceiling if you want.
Keith Mathewson is offline   Reply With Quote
Old 03-05-2013, 10:46 PM   #3
Rewards Points: 150
The 36" is a minimum. see the following from the ICC Residential Code.
R312.1.2 Height.
Required guards at open-sided walking surfaces, including stairs, porches, balconies or landings, shall be not less than 36 inches (914 mm) high measured vertically above the adjacent walking surface, adjacent fixed seating or the line connecting the leading edges of the treads.
Exceptions:
1. Guards on the open sides of stairs shall have a height not less than 34 inches (864 mm) measured vertically from a line connecting the leading edges of the treads.2. Where the top of the guard also serves as a handrail on the open sides of stairs, the top of the guard shall not be less than 34 inches (864 mm) and not more than 38 inches (965 mm) measured vertically from a line connecting the leading edges of the treads. Remember; the above is for a guard, not a handrail. You might want to check with your local jurisdiction to confirm the regulations that apply where you live.
TheCamper is offline   Reply With Quote
Crooked Railing RomanDesign Carpentry 4 10-12-2012 06:37 PM
Getting deck railing posts plumb S-L-O-W-L-Y (!) chrisv2 Building & Construction 5 09-04-2012 08:02 AM
Attaching porch railing to brick wiz561 Building & Construction 0 06-19-2011 02:39 PM
Tile under or around a railing? RandyKlein Remodeling 3 06-13-2010 10:08 AM
How to fix broken step railing? robertr4836 Carpentry 2 04-18-2008 12:19 PM
