Old 01-19-2011, 08:29 PM   #1
Interesting Construction Project
The basis behind this question is with regarding a property I am interested in purchasing and need some opinions from people involved in construction for some options.
The building is a church that was built in 1888 and over the years has been converted to a community center and now for sale and my plan would be to convert it to single family residential. Putting aside permits and all that we are talking about structure.
The main room is 25 feet by 45 feet with 30 feet ceilings and the intent would be to build a "loft" style level within part of that space, however the flooring is slightly wavey; we can assume in the most few inches drop across the room. It has a hardwood floor that is need of repair so we assume that will be completely removed to the joists which I think are 4inch thick (height unsure).
My main concern is how I can level that floor for finishing as well so I can build a loft within the space.
25 feet is the width and in the rooms below that space there is the main beam that runs the 45 feet.
I want to look at other options than jacking up parts of the floor as the rooms under will be used and I cant have jacks everywhere so all ideas and suggestions are welcomed.
Crzy_Canuck is offline   Reply With Quote
Old 01-19-2011, 08:39 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
Find a good architect & Engineer in your area. Most likely Steel would be spec'd for what you are wanting to do.
gregzoll is online now   Reply With Quote
Old 01-20-2011, 07:37 AM   #3
gravity always wins
You could shim or sister the low joists.
Old 01-20-2011, 08:41 PM   #4
I was thinking of adding sister joists for each of the low ones. Would it be appropriate if needed to have the sister joist rest on a shim ontop of the beams to bring them to the correct height if needed?
Old 01-20-2011, 09:05 PM   #5
gregzoll's Avatar
The shim would have to be a steel plate. Best to talk to a Structural Engineer to see what really needs to be done, then go with their assessment.
Old 01-22-2011, 11:21 AM   #6
gravity always wins
Certainly. It's common practice. Different thicknesses of plywood work well. Tack them so that they can't slip out, and make sure they are big enough to catch the whole area where the joist lays on the beam.
my floor refurbish project Knucklez Project Showcase 28 08-10-2010 09:14 AM
Kitchen Project Complete with pics! baksdak Project Showcase 30 03-10-2009 03:13 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
