Insulation Woes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 08:19 AM   #1
Insulation woes
I have a bedford stone house,just rplace a window recently and noticed 2-3 inches of space between stone and interior wood frame/barrier. Is this normal? Should i correct and how?
mtaylor is offline   Reply With Quote
Old 07-07-2010, 08:47 AM   #2
I'd think that space is a good thing. You want to keep the lumber away from a source of moisture (cold stone). If you could seal the back of the studs or the stone wall, it might be beneficial to keep moisture issues at bay.
JH
Hohn is offline   Reply With Quote
The Following User Says Thank You to Hohn For This Useful Post:
mtaylor (07-07-2010)
Old 07-07-2010, 09:56 AM   #3
get some cans of spray foam and fill those cavities!
wombosi is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Old home insulation woes nowwhatnapster Building & Construction 15 11-02-2008 11:59 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
