Insulation In Utility Room - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 09:04 PM   #1
Insulation in utility room
Hello from Earth Texas. We are having problems keeping our water pipes in the utility room from freezing. We have had two below 0 cold fronts in the last week and they are frozen again. The hot froze first and then the cold. We have insulation pretty thick inside the wall and even more added when it was repaired last Sunday. We had another front come in today and it is frozen again.Any suggestions? It has a concrete floor and is on the north side of our house. Thanks!! cs
charliesioux is offline   Reply With Quote
Old 02-09-2011, 07:33 AM   #2
Retired
Edgar214's Avatar
Did you leave the hot & cold water running?
Mike
THE ONLY THING THAT'S CONSTANT IS CHANGE
Edgar214 is offline   Reply With Quote
Old 02-09-2011, 07:45 AM   #3
Retired G.C.
? is it just the pipes in that room?
are the pipes exposed or in the wall?
do they go up into the ceiling?
are the pipes themselves insulated?
You can get some heat tape and wrap the pipes and only turn on when you need it!
CharlieO is offline   Reply With Quote
Room Air Purifier - which is best? nhart Appliances 17 07-29-2014 09:00 PM
My utility room's wiring, before rewiring WillK Electrical 0 01-07-2011 10:44 PM
Use of radient barrier insulation JHM161 General DIY Discussions 3 02-13-2009 01:38 PM
Sound insulation for home theater room david.plymouth Building & Construction 3 02-08-2009 09:49 PM
Installing Utility Sink In Laundry Room - Main Floor pieman312 Plumbing 13 01-09-2008 08:13 PM
