Which Insulation To Use?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 09:43 AM   #1
Question
Which Insulation to use??
Guys I live in Upstate NY. It is very cold here in the winter. We typically get about 6 months of Winter. Going to re-do upstairs. Going to install all new insulation in the Attic and walls upstairs.
I'm thinking R-49 for the attic....
And either R-18 or R-22 for the walls...
And R-19 for the crawl spaces in our extra room upstairs...
This sound about right????
Tdoggy187 is offline   Reply With Quote
Old 02-26-2008, 06:45 PM   #2
General Contractor
joasis's Avatar
What material? If possible, get it done with cellulose.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 02-26-2008, 07:45 PM   #3
Smile
ok it says....
The add says Owens Corning insulation Products. It looks like Fiber Glass Insulation I suppose??? Should I use this type or something else. I'm a beginner so please I'm open to any advice possible...
Old 02-26-2008, 11:16 PM   #4
How thick (deep) or your walls?
redline is offline   Reply With Quote
Old 02-27-2008, 08:26 PM   #5
Do it right.
If you're running 2x4 studs i don't even think its possible to shove r-22 in there (ive never tried) as for the attic, i would think r-38 would be sufficient but the more the better in my opinion... especially if you've ever had an ice dam.
SubSailor is offline   Reply With Quote
Old 02-28-2008, 10:37 PM   #6
Wink
From what i can see...
Walls don't look to deep at all. Plaster and lathe, no insulation. Haven't measured yet though.
R-38 Sounds good. I really have no idea...
Old 02-29-2008, 03:20 AM   #7
Your studs are probably true 4 inch.
Old 02-29-2008, 10:23 AM   #8
Thumbs up
Is that...
Is that good or bad?? Can I get insulation in there?? Any idea what type??? man I wish I grew up learning Construction
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 03:38 PM
