Insulation Under A Metal Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 09:34 AM   #1
cabin insulation ?
we have built a cabin but it will not be used in the winter, was thinking about just installing 6 mil plastic sheeting on the loft roof rafters and skiping the cost of insulation, was thinking the plastic would work fine ??
bigval is offline   Reply With Quote
Old 09-13-2010, 12:53 PM   #2
steveel's Avatar
No insulation, no vapor barrier! You're pretty certain to have a major condensation problem that way.
steveel is offline   Reply With Quote
Old 09-13-2010, 02:00 PM   #3
Actually the plastic would be a vapor barrier
But it won't hold much heat
There are plenty of times in the Spring/Fall when its cold enough that insulation would help
Are you insulating the walls ?
There won't be any heat source at all in the cabin ?
Old 09-13-2010, 02:03 PM   #4
joed's Avatar
Rewards Points: 12,924
If no insulation I would just leave the rafters open and paint eveything.
Old 09-13-2010, 02:51 PM   #5
insulation under a metal roof
how do you keep the sweating of the metal roofing from the fiberglass insulation?
Old 09-13-2010, 08:12 PM   #6
jlhaslip's Avatar
Rewards Points: 2,200
There needs to be a layer of roofing paper or felt under the tin.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 09-13-2010, 08:16 PM   #7
jlhaslip's Avatar
Insulation works in both cold and hot seasons.
Without Insulation, you need to be pretty well shaded by trees in the summer to avoid over-heating the cabin.
Old 09-14-2010, 06:04 AM   #8
so I'm thinking I should staple plastic in between each rafter before installing the insulation? (to keep the rain effect off the fiberglass insulation)
Old 09-14-2010, 06:29 AM   #9
jlhaslip's Avatar
I wouldn't use plastic. Try something that breathes and won't become a vapour barrier.
Old 09-14-2010, 06:35 AM   #10
like what? and how do we keep the moisture from the insulation or will the moisture stop when the insulation is installed?
Old 09-14-2010, 09:25 AM   #11
Rewards Points: 502
are you insulating or not?
Are you talking a vaulted ceiling over a sleeping loft?
Id do sheeting, paper then the metal at a minimum for somewere you are going to try to sleep in during a rain storm.
I'd leave the rafters open and use a shiny or white metal roof to reflect the heat.
If you want to add insulation later, it will be much easier with open rafters.
forresth is offline   Reply With Quote
Old 09-14-2010, 11:14 AM   #12
Registered User
Rewards Points: 5,520
Understand the problem: http://www.buildingscience.com/docum...f%20insulation
Research other solutions: http://www.buildingscience.com/searc...f%20insulation
I’ve never done metal roofs, so I won’t answer. Hope this helps...
Gary
Old 09-14-2010, 11:36 AM   #13
the roof is already on we are going up this weekend to do the insulation and finish the lost ceiling? and if we just install the insulation with out plastic before it won't the moisture ruin the fiberglass?
Old 09-14-2010, 12:03 PM   #14
Rewards Points: 502
there needs to be airflow beween the roof and the insulation. that airflow should maintain near outside temps on the roof side of the insulation to eliminate the condensation.
if you want to just fill it all up with insulation, I think the spay in foam is about the only way to do it without creating a mold problem.
Old 09-14-2010, 12:24 PM   #15
so should we just forget the plastic and take our chances with the insulation?
your thinking is the air gap left with prevent moisture?
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
Blown Insulation - Flat roof AndrewF Roofing/Siding 1 12-31-2009 06:41 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Air cavity required behind spray foam roof insulation BigJimmy Building & Construction 9 06-08-2008 12:45 PM
