Insulation Under House On Pilings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2009, 02:30 PM   #1
rvd
Insulation under house on pilings
House is on short pilings (3ft), open on all sides. How best to insulate under home in MidAtlantic (sub zero) to prevent pipes/drains from freezing?
rvd is offline   Reply With Quote
Old 12-06-2009, 03:05 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 340
open on all sides.
Ayuh,... Close it in on all 4 sides,+ insulate the banking...
Bondo is online now   Reply With Quote
Old 12-06-2009, 06:41 PM   #3
Spray foam.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 12-07-2009, 07:47 AM   #4
ccarlisle's Avatar
You can't leave the pipes and drains on the exterior 'envelope' of your house and hope they won't freeze. The solution is to either bring them to the interior and insulate around them, or leave themn where they are and create a new exterior envelope that encloses them.
Now you can seal in the four sides and insulate the new space created (like a crawlspace) or sprayfoam the underside of the floor creating the thermal break they need.
I'm with jaros on this.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-07-2009, 08:02 AM   #5
ArmchairDIY's Avatar
You also need to consider water and sewer lines were they enter and exit the house not just between the floor joists.
I think spray foam would be the best choice, but expensive.
Rodents entering the insulation from below is also a big issue with fiberglass, it may also be a problem with spray foam, but I can't say for sure.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself! ArmchairDIY.com
ArmchairDIY is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 10:04 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
Cantilevered floor insulation rickswa Building & Construction 5 01-02-2008 01:08 AM
