Insulation Under Fiberglass Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 11:27 PM   #1
Insulation under fiberglass deck
Doing 2nd floor fiberglass deck above living area. Do I HAVE to put baffles before putting in the insulation for ventilation?
Dangis is offline   Reply With Quote
Old 03-05-2011, 08:58 AM   #2
Rewards Points: 5,336
I don't know what you mean by this.
Where is this going? Inside? Outside? The attic?
Ron
Old 03-05-2011, 12:12 PM   #3
Rafter vents would go under plywood deck between floor joists and it would vent through the soffit in the front of the deck, but there is nothing on the other end, just ledger board.
Old 03-05-2011, 12:57 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... It's gotta be vented from both ends, or it ain't vented at all...
Old 03-05-2011, 10:17 PM   #5
Don't use baffles they'll rot away under the deck
Stainless steel is offline   Reply With Quote
Old 03-05-2011, 10:20 PM   #6
Build a pitched roof under the deck for water run off then rubber roof it ,then build deck inside your posts free floating and be sure it is able to lift out for easy seasonal cleaning.Drill thumb holes in sections of the deck instead of using handles or claps.
Old 03-06-2011, 12:28 PM   #7
The old deck that we demolished had baffles. Plus the architect is asking for vented soffit in front of the deck.
Tags
decking , insulation
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
Blown in insulation added to fiberglass batts bsbrooks1 Building & Construction 2 02-10-2011 11:43 PM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 11:50 AM
How to seal fiberglass deck surface? darsunt Painting 1 08-05-2010 08:08 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
